Saw Chain care and sharpening tips?
   / Saw Chain care and sharpening tips? #41
I try to keep them about the same when hand filing- same number of strokes, maybe an extra if one didn't cut well. When I use the Oregon grinder that makes them all the same length. Everything I've read from chain manufacturers says to keep tooth length consistent but they don't say what the tolerance is. I think a reasonably small variation is ok.
   / Saw Chain care and sharpening tips? #42
Too much emphasis on making each cutter exactly the same, rather than just making each cutter sharp.
Not for the OCD in us. They need to be EXACTLY the same :D
For anyone who has seen my hand filing, they understand why I use a machine. You would NOT want me hand filing your saw chains :D
I have to admire those who hand file well.
   / Saw Chain care and sharpening tips? #43
Those who cannot hand file, must have never used a granberg.
   / Saw Chain care and sharpening tips? #44
That would be me :D
I have to admire those that can hand file well.
   / Saw Chain care and sharpening tips? #46
   / Saw Chain care and sharpening tips? #47
Granberg is a file guide.
You are still filing by hand....
But the file clamps in a jig that is clamped on the bar. Its impossible to file any other angle than what you set the jig at.
I can sharpen a chain (on the saw) as fast as it would take me to remove and reinstall a chain.
   / Saw Chain care and sharpening tips? #48
I thought a granberg is an electric grinder that clamps on the bar?
   / Saw Chain care and sharpening tips? #50
Fact check. Actually there are electric versions, not just the hand version
12 Volt - Granberg International
   / Saw Chain care and sharpening tips? #51
Yep.
Everyone I know in the business and amature chainsaw owners as well simply refer to them as a granberg.
Kinda like people calling an adjustable wrench a "crescent" wrench. Well......"crescent" makes more than just adjustable wrenches too.
   / Saw Chain care and sharpening tips? #54
My uncle made a cool chain saw chain storage container out of a 6" PVC pipe. He cut the pipe long enough to contain his longest chain and drilled about a half inch hole/slot through the top and used a removable dowel to put through the hole/slot he drilled which the chains would hang from down into the PVC. He had a cap on it to keep the weather out. Keeps them from getting tangled or weather from reaching them and rusting them etc. Worked very nicely.
   / Saw Chain care and sharpening tips? #55
A question for Granberg Precision Grinder or the File -N-Joint (with the bar clamp) users...
How does it handle sloppy chains? it seems like just a little (sideways) movement in the chain would change the angle??
   / Saw Chain care and sharpening tips? #56
It has an adjustable support on each side of the chain to eliminate that. It will also hold a flat file so you can lower the rakers a known amount by turning the dial that holds file height, each number = .010 inch
   / Saw Chain care and sharpening tips? #57
I’ve had pretty good luck with the Dremel chainsaw sharpening attachment. Dremel is cordless so it goes in the woods, can touch up the chain without leaving the bar.
   / Saw Chain care and sharpening tips? #59
I don't sharpen anymore.......much easier to take my chains to local saw shop......for $5........he sharpens them like new......when they are too worn down......he makes me a new one. I always have 3 or 4 sharp chains in the shop. Nothing wrong with easy.
No argument in having a good local sharpener for your chains. I am learning how to best sharpen about every cutting tool I own but the chain is one I definitely have not mastered.
There are folks that will touch up their chains every tank or two of fuel used. That keeps a nice sharp chain in constant use and keeps all the angles correct. Running a chain till it is real dull usually wrecks the chain.
This makes perfect sense. Touching up regularly even though I know it would be best, is not in my DNA... yet.
Use a power sharpener, factory fresh performance every time .
What power sharpeners are you suggesting?
I like filing and use a granberg.
Never liked taking the chain off and using a machine.
Can sharpen a chain almost as fast as taking one off.
And the machines IMO, shorten a chains life because they remove more material than is needed.
I like the idea of a Granberg but just how quick and easy to align?
My modus operandi has been to wear them hard until dull and then hand file without a guide and then realize I need to buy a new one. So... I always have one new one on stand by.
   / Saw Chain care and sharpening tips? #60
Most people do not carry a mechanical chain sharpener out into the woods.
You need to define "mechanical", does that include the Granberg and the Timberline?
And with battery powered Dremels etc. it's easy to carry a powered chain sharpener.
Yup, that's confusing. I always thought the term "hand filing" meant a hand a file a chain, usually on the saw.
That's why I referred to it as
Then do a "Grandberg sharpening" to make sure my angles are right.
That may be good for you, but the OP is not in your class of filing yet. Probably not even with a Grandberg.
I always hold the chain in a gloved hand.
<snip>
Generally one only uses a few different angles, so you get it set up for your chain and use it repeatedly.
Bailey's has a good video on it:
<snip>
IF you are just "getting in to it" and do not have either a good or inexpensive dealer to sharpen chains (my local dealer charged $12 for a 20" chain back in 2009, and sometimes ruined the chain) I'd recommend looking into tools like the "Stihl 2 in 1 chainsaw sharpener" and the Timberline.
Remember a dull cutter, either on a chainsaw chain or a knife, is dangerous unless you are cutting soft butter.
The timberline looks like a limited Grandberg,
The following specialty chains are not currently compatible with the Timberline Sharpener: carbide chains (requiring a diamond bit for sharpening) and ripping/milling chains requiring a 5˚- 15˚ sharpening angle (our standard angle guides are set at 30˚ and our accessory angle guides provide 25˚ and 35˚).
Since I do a lot of milling it wasn't for me :(
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2014 BMW 5 SERIES SEDAN (A59905)
2014 BMW 5 SERIES...
