Chain sharpening
/ Chain sharpening #41
I mark the top of a tooth with magic marker so I know when I've done all the teeth.
That's what I do. I keep a black Sharpie marker to color the top plate of the first tooth I'm going to sharpen. (one of my saws has an odd number of teeth - so I just start where I have two teeth in a row n the same side of the bar.)
/ Chain sharpening #43
One square grinder, one round grinder and a raker/depth gauge grinder. There’s a huge difference in having a consistent chain when you’re falling timber all the time you need predictability.
/ Chain sharpening #44
Ours got so much oil on them, markers doesn't cut it. Most of our chains don't have different attachment/special link either. I've learned to simply watch for freshly sharpened teeth to come around. :unsure:
/ Chain sharpening #45
I have 3 chainsaws that I rotate as I have a lot of tree and subsequent cleanup. After each use I clean using compressed air, then tighten chainsaw, and then sharpen. Before putting the chainsaw away I make sure the oil and 50:1 gas is full. I always use the pre-mixed gallon cans which are expensive but takes the guess work out.
I did learn that the bar itself should be greased and there is a tool for that.
Oregon 26365 Chainsaw Grease Gun
There’s two schools of thought on that. I don’t grease mine, allowing the B&C oil to do the job and have never had a problem. If you do grease do it often as it will create a ring around the sprocket, which won’t allow oil to get to the sprocket.
Not cutting straight is usually from the rakers not matching. A good file guide can help prevent that.
/ Chain sharpening #46
There’s two schools of thought on that. I don’t grease mine, allowing the B&C oil to do the job and have never had a problem. If you do grease do it often as it will create a ring around the sprocket, which won’t allow oil to get to the sprocket. Not cutting straight is usually from the rakers not matching. A good file guide can help prevent that.
Not cutting straight is usually from grinding/sharpening one side of your chisel teeth, more than the other. The left and right teeth need to be the same for a good cut.
None of my bars have a grease hole for the tip sprocket. Never had that bearing fail either. I replace about one bar per summer for being bent or simply wore out.. We rarely run out of bar oil but it sure sounds funny when you do! . Ya, we're hard on them.
/ Chain sharpening #47
I just wipe the top plate with my finger, then draw with the marker. It's not a permanent mark, but it easily lasts through the sharpening process. If I had a grease pencil with me, I'd use that, but for some reason, tey tend to disappear on me far more frequently than Sharpie markers.
/ Chain sharpening #48
I’ve had the most crooked cut problems aside from the obvious damaged chain from a worn bar. Once it starts happening I take it off and grind it on my strip sander and that fixes the problem.
/ Chain sharpening #51
This might be a stupid qestion, but what are you grinding off??
/ Chain sharpening #52
ther are burs or raised edges on a worn bar that need to be filed - flat sides of bars is what i do.. they have a tool i have seen for truing up a bar - never bought one though.
/ Chain sharpening #53
Gee, takes two minutes to knock those bar burrs off. Been there, done that, but these will make your cut not straight?
/ Chain sharpening #54
i think the cutters that are sharpened wrong or differently than the others will do that. if i nderstood you correctly.
/ Chain sharpening #55
Both can cause a cut to be off.
/ Chain sharpening #56
Burrs on the bar and given enough use they get tracks worn in them and need flattened back out.
/ Chain sharpening
I tried special Stihl file. Continue to use the Dremel with round stones. Bought a new set of 3. Got at Lowes.
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2024 John Deere TX (A64119)
2024 John Deere TX...
2020 Colombo CTA 6500 (A64119)
2020 Colombo CTA...
2017 Gehl RS6-34 (A64119)
2017 Gehl RS6-34...
Plastic Drain Pipe (A64119)
Plastic Drain Pipe...
2007 Flatbed Dump (A62613)
2007 Flatbed Dump...
