Chain sharpening
/ Chain sharpening #41
I mark the top of a tooth with magic marker so I know when I've done all the teeth.
That's what I do. I keep a black Sharpie marker to color the top plate of the first tooth I'm going to sharpen. (one of my saws has an odd number of teeth - so I just start where I have two teeth in a row n the same side of the bar.)
/ Chain sharpening #43
One square grinder, one round grinder and a raker/depth gauge grinder. There’s a huge difference in having a consistent chain when you’re falling timber all the time you need predictability.
/ Chain sharpening #44
Ours got so much oil on them, markers doesn't cut it. Most of our chains don't have different attachment/special link either. I've learned to simply watch for freshly sharpened teeth to come around. :unsure:
/ Chain sharpening #45
I have 3 chainsaws that I rotate as I have a lot of tree and subsequent cleanup. After each use I clean using compressed air, then tighten chainsaw, and then sharpen. Before putting the chainsaw away I make sure the oil and 50:1 gas is full. I always use the pre-mixed gallon cans which are expensive but takes the guess work out.
I did learn that the bar itself should be greased and there is a tool for that.
Oregon 26365 Chainsaw Grease Gun
There’s two schools of thought on that. I don’t grease mine, allowing the B&C oil to do the job and have never had a problem. If you do grease do it often as it will create a ring around the sprocket, which won’t allow oil to get to the sprocket.
Not cutting straight is usually from the rakers not matching. A good file guide can help prevent that.
/ Chain sharpening #46
There’s two schools of thought on that. I don’t grease mine, allowing the B&C oil to do the job and have never had a problem. If you do grease do it often as it will create a ring around the sprocket, which won’t allow oil to get to the sprocket. Not cutting straight is usually from the rakers not matching. A good file guide can help prevent that.
Not cutting straight is usually from grinding/sharpening one side of your chisel teeth, more than the other. The left and right teeth need to be the same for a good cut.
None of my bars have a grease hole for the tip sprocket. Never had that bearing fail either. I replace about one bar per summer for being bent or simply wore out.. We rarely run out of bar oil but it sure sounds funny when you do! . Ya, we're hard on them.
/ Chain sharpening #47
I just wipe the top plate with my finger, then draw with the marker. It's not a permanent mark, but it easily lasts through the sharpening process. If I had a grease pencil with me, I'd use that, but for some reason, tey tend to disappear on me far more frequently than Sharpie markers.
/ Chain sharpening #48
I’ve had the most crooked cut problems aside from the obvious damaged chain from a worn bar. Once it starts happening I take it off and grind it on my strip sander and that fixes the problem.
/ Chain sharpening #51
This might be a stupid qestion, but what are you grinding off??
/ Chain sharpening #52
ther are burs or raised edges on a worn bar that need to be filed - flat sides of bars is what i do.. they have a tool i have seen for truing up a bar - never bought one though.
/ Chain sharpening #53
Gee, takes two minutes to knock those bar burrs off. Been there, done that, but these will make your cut not straight?
/ Chain sharpening #54
i think the cutters that are sharpened wrong or differently than the others will do that. if i nderstood you correctly.
/ Chain sharpening #55
Both can cause a cut to be off.
/ Chain sharpening #56
Burrs on the bar and given enough use they get tracks worn in them and need flattened back out.
/ Chain sharpening
I tried special Stihl file. Continue to use the Dremel with round stones. Bought a new set of 3. Got at Lowes.
Excavator trenching bucket- one bucket per lot (A63118)
Excavator...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2022 Timpte 1420 All-Aluminum Equipment Trailer (A63118)
2022 Timpte 1420...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
