Electrical wiring challenge
   / Electrical wiring challenge
Tig said:
6 Wires. Check with the inspector, I am not an electrician. I am talking minimum in theory.
1 You need a return wire to go to the shack for both lights and outlets (white wire?).
2 An unswitched hot for your outlets.
3&4 Two wires for your inside light switch (switched hot).
5&6 Two wires for your outside light switch (another switched hot)
Plus one ground wire, not detailed but essential.
PM me and I'll draw it out for you.
OK so is 6 the absolute Min?
   / Electrical wiring challenge #13
Any less and the outlets will have to turn off and on with the lights.
Ok the answer is that it can be done with 4 wires.
The challenge is who will be the first to figure it out and provide us a drawing.
   / Electrical wiring challenge #19
Dang it you're right! 4 wires.
Run hot and return out to the shed (1&2) and switch one end of the bulb filament between hot and return out there. Run a wire back to the house (3) and switch the other end of the filament between hot and return there. Second bulb switched the same as the first, 4th wire.
I have no idea if that is ok under local electrical codes.
Very Good!! You figured that out pretty fast.
I see no reason why it would not be legal.
Galvanized steel fence (A53424)
Galvanized steel...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
CATERPILLAR 740B OFF ROAD DUMP TRUCK (A52705)
CATERPILLAR 740B...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
