Electrical wiring challenge
   / Electrical wiring challenge
Tig said:
6 Wires. Check with the inspector, I am not an electrician. I am talking minimum in theory.
1 You need a return wire to go to the shack for both lights and outlets (white wire?).
2 An unswitched hot for your outlets.
3&4 Two wires for your inside light switch (switched hot).
5&6 Two wires for your outside light switch (another switched hot)
Plus one ground wire, not detailed but essential.
PM me and I'll draw it out for you.
OK so is 6 the absolute Min?
   / Electrical wiring challenge #13
Any less and the outlets will have to turn off and on with the lights.
Ok the answer is that it can be done with 4 wires.
The challenge is who will be the first to figure it out and provide us a drawing.
   / Electrical wiring challenge #19
Dang it you're right! 4 wires.
Run hot and return out to the shed (1&2) and switch one end of the bulb filament between hot and return out there. Run a wire back to the house (3) and switch the other end of the filament between hot and return there. Second bulb switched the same as the first, 4th wire.
I have no idea if that is ok under local electrical codes.
Very Good!! You figured that out pretty fast.
I see no reason why it would not be legal.
Utility Trailer (A52377)
Utility Trailer...
2006 FORD F-750 XL 4X2 SUPER DUTY CRANE TRUCK (A51406)
2006 FORD F-750 XL...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 66"...
Electric Mobility Scooter (A54815)
Electric Mobility...
2008 Chevrolet Impala Sedan (A53424)
2008 Chevrolet...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
