Electrical wiring challenge
   / Electrical wiring challenge
Tig said:
6 Wires. Check with the inspector, I am not an electrician. I am talking minimum in theory.
1 You need a return wire to go to the shack for both lights and outlets (white wire?).
2 An unswitched hot for your outlets.
3&4 Two wires for your inside light switch (switched hot).
5&6 Two wires for your outside light switch (another switched hot)
Plus one ground wire, not detailed but essential.
PM me and I'll draw it out for you.
OK so is 6 the absolute Min?
   / Electrical wiring challenge #13
Any less and the outlets will have to turn off and on with the lights.
Ok the answer is that it can be done with 4 wires.
The challenge is who will be the first to figure it out and provide us a drawing.
   / Electrical wiring challenge #19
Dang it you're right! 4 wires.
Run hot and return out to the shed (1&2) and switch one end of the bulb filament between hot and return out there. Run a wire back to the house (3) and switch the other end of the filament between hot and return there. Second bulb switched the same as the first, 4th wire.
I have no idea if that is ok under local electrical codes.
Very Good!! You figured that out pretty fast.
I see no reason why it would not be legal.
2015 Freightliner M2 106 Ambulance (A55788)
2015 Freightliner...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
UNUSED FUTURE FT-13 EXCAVATOR (A54756)
UNUSED FUTURE...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
2005 Ford F-750 Truck (A53422)
2005 Ford F-750...
