Electrical wiring challenge
   / Electrical wiring challenge
Tig said:
6 Wires. Check with the inspector, I am not an electrician. I am talking minimum in theory.
1 You need a return wire to go to the shack for both lights and outlets (white wire?).
2 An unswitched hot for your outlets.
3&4 Two wires for your inside light switch (switched hot).
5&6 Two wires for your outside light switch (another switched hot)
Plus one ground wire, not detailed but essential.
PM me and I'll draw it out for you.
OK so is 6 the absolute Min?
   / Electrical wiring challenge #13
Any less and the outlets will have to turn off and on with the lights.
Ok the answer is that it can be done with 4 wires.
The challenge is who will be the first to figure it out and provide us a drawing.
   / Electrical wiring challenge #19
Dang it you're right! 4 wires.
Run hot and return out to the shed (1&2) and switch one end of the bulb filament between hot and return out there. Run a wire back to the house (3) and switch the other end of the filament between hot and return there. Second bulb switched the same as the first, 4th wire.
I have no idea if that is ok under local electrical codes.
Very Good!! You figured that out pretty fast.
I see no reason why it would not be legal.
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
2017 Ford F-450 Crew Cab Mason Dump Truck (A55788)
2017 Ford F-450...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
2017 TAKEUCHI TB240 EXCAVATOR (A52705)
2017 TAKEUCHI...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
2013 Ford F-150 (A55788)
2013 Ford F-150...
