BX Hood Shake
/ BX Hood Shake #21
I put bumpers on mine and it helped a lot. Another area for a noise is a improperly adjusted MMM that does not contact the stops when it is up.
/ BX Hood Shake #23
If you find that annoying you wouldn't like an early VW diesel--they did the same thing, but I considered it a tradeoff for getting 50 mpg. It's a diesel engine with solid motor mounts in a small vehicle. Later on VW switched to rubber motor mounts and things really smoothed out. Perhaps Kubota will do the same thing.
/ BX Hood Shake #24
Interesting discussion .. my theory on the hood shake is that its caused by the flywheel being at the front where the engine is suspended on rubber mounts.
/ BX Hood Shake #26
On the b2200 I used to have I used an adhesive insulation foam strip on each side where the hood contacts the sides. Stopped most of the noise. My 2012 2620 doesn't make a sound when shutting down....maybe luck?
/ BX Hood Shake
Glad to hear that as I just signed the deal to trade the BX in on a new B2620.
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Allis Chalmers WD45 Tractor (A66285)
Allis Chalmers...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
