BX Hood Shake
/ BX Hood Shake #21
I put bumpers on mine and it helped a lot. Another area for a noise is a improperly adjusted MMM that does not contact the stops when it is up.
/ BX Hood Shake #23
If you find that annoying you wouldn't like an early VW diesel--they did the same thing, but I considered it a tradeoff for getting 50 mpg. It's a diesel engine with solid motor mounts in a small vehicle. Later on VW switched to rubber motor mounts and things really smoothed out. Perhaps Kubota will do the same thing.
/ BX Hood Shake #24
Interesting discussion .. my theory on the hood shake is that its caused by the flywheel being at the front where the engine is suspended on rubber mounts.
/ BX Hood Shake #26
On the b2200 I used to have I used an adhesive insulation foam strip on each side where the hood contacts the sides. Stopped most of the noise. My 2012 2620 doesn't make a sound when shutting down....maybe luck?
/ BX Hood Shake
Glad to hear that as I just signed the deal to trade the BX in on a new B2620.
2022 BIGHORN EXPLORER 400 EFI UTV (A62130)
2022 BIGHORN...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2004 CATERPILLAR D5N XL HIGH TRACK CRAWLER DOZER (A62129)
2004 CATERPILLAR...
UNUSED RAYTREE RABC44 - 44" ARTICULATING CUTTER (A62131)
UNUSED RAYTREE...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
2020 Case IH 475 Speed Disk (A63109)
2020 Case IH 475...
