BX Hood Shake
/ BX Hood Shake #21
I put bumpers on mine and it helped a lot. Another area for a noise is a improperly adjusted MMM that does not contact the stops when it is up.
/ BX Hood Shake #23
If you find that annoying you wouldn't like an early VW diesel--they did the same thing, but I considered it a tradeoff for getting 50 mpg. It's a diesel engine with solid motor mounts in a small vehicle. Later on VW switched to rubber motor mounts and things really smoothed out. Perhaps Kubota will do the same thing.
/ BX Hood Shake #24
Interesting discussion .. my theory on the hood shake is that its caused by the flywheel being at the front where the engine is suspended on rubber mounts.
/ BX Hood Shake #26
On the b2200 I used to have I used an adhesive insulation foam strip on each side where the hood contacts the sides. Stopped most of the noise. My 2012 2620 doesn't make a sound when shutting down....maybe luck?
/ BX Hood Shake
Glad to hear that as I just signed the deal to trade the BX in on a new B2620.
Informational Lot - Financing (A63118)
Informational Lot...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
Crabtree 17yd Dirt Scraper (A64047)
Crabtree 17yd Dirt...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
