BX Hood Shake
/ BX Hood Shake #21
I put bumpers on mine and it helped a lot. Another area for a noise is a improperly adjusted MMM that does not contact the stops when it is up.
/ BX Hood Shake #23
If you find that annoying you wouldn't like an early VW diesel--they did the same thing, but I considered it a tradeoff for getting 50 mpg. It's a diesel engine with solid motor mounts in a small vehicle. Later on VW switched to rubber motor mounts and things really smoothed out. Perhaps Kubota will do the same thing.
/ BX Hood Shake #24
Interesting discussion .. my theory on the hood shake is that its caused by the flywheel being at the front where the engine is suspended on rubber mounts.
/ BX Hood Shake #26
On the b2200 I used to have I used an adhesive insulation foam strip on each side where the hood contacts the sides. Stopped most of the noise. My 2012 2620 doesn't make a sound when shutting down....maybe luck?
/ BX Hood Shake
Glad to hear that as I just signed the deal to trade the BX in on a new B2620.
Single Cedar Glider (A65583)
Single Cedar...
Gravely Zero Turn Mower (A64194)
Gravely Zero Turn...
SKIDDED PLAIN/WASTE WATER TANK (A65643)
SKIDDED...
2017 TAKEUCHI TL8 SKID STEER (A65053)
2017 TAKEUCHI TL8...
2007 Mack CHN614 Day Cab Truck, VIN # 1M1AJ06Y97N005399 (A65563)
2007 Mack CHN614...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
