BX Hood Shake
/ BX Hood Shake #21
I put bumpers on mine and it helped a lot. Another area for a noise is a improperly adjusted MMM that does not contact the stops when it is up.
/ BX Hood Shake #23
If you find that annoying you wouldn't like an early VW diesel--they did the same thing, but I considered it a tradeoff for getting 50 mpg. It's a diesel engine with solid motor mounts in a small vehicle. Later on VW switched to rubber motor mounts and things really smoothed out. Perhaps Kubota will do the same thing.
/ BX Hood Shake #24
Interesting discussion .. my theory on the hood shake is that its caused by the flywheel being at the front where the engine is suspended on rubber mounts.
/ BX Hood Shake #26
On the b2200 I used to have I used an adhesive insulation foam strip on each side where the hood contacts the sides. Stopped most of the noise. My 2012 2620 doesn't make a sound when shutting down....maybe luck?
/ BX Hood Shake
Glad to hear that as I just signed the deal to trade the BX in on a new B2620.
2012 Husqvarna YTH21K46 46in. Riding Lawn Mowers (A64557)
2012 Husqvarna...
2015 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2015 International...
Carry-On 5' x 8' Utility Trailer (A66408)
Carry-On 5' x 8'...
Hesston 3717 4-basket Pull-type Hay Tedder (A66408)
Hesston 3717...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
Woods 15ft. Batwing Mower (A65640)
Woods 15ft...
