AZ ranch
/ AZ ranch
I went ahead and put perforated drain pipe behind the block I have done so far.
I know, some think I’m nuts for doing the drain pipe when I haven’t even finished the first course yet, but I’ve had multiple cave-ins and I’m just trying to make sure I can get some wall up asap by the most susceptible area to cave.
I even have the apron area to pour yet. That’s the section with all the pieces of rebar.
/ AZ ranch #1,383
I just now found my tool for smoothing the seam between blocks. I may not use it until the 5th course as everything below that will be covered in dirt, inside and out.
A small kitchen spoon works good as well.
You know you’ll misplace it again before course 5!!
/ AZ ranch
About 12 block a day is what my back will tolerate. Then there’s tarring the outside and hauling/washing gravel for backfill, grinding and placing rebar, etc. The actual laying of block is about 25% of the job, so I’m happy with the progress rate.
/ AZ ranch #1,391
Looks great from my house sir!!
/ AZ ranch #1,392
Are you going to fill all the blocks with concrete? I found that a metal feed scooper works great for this. I just scoop the concrete out of the wheelbarrow and into the block.
/ AZ ranch
I’ve already started filling them. I mix up a batch in the mixer, pour it into a mixing tray, and then I’ve been using some old plastic flower pots to scoop it into the block. Since I’m filling at the halfway point, I’m sticking little 2 ft pieces of rebar vertically in every block to help make a stronger bind with the top half when I fill it. That’s in addition to the vertical rebar that is 5 ft long that I put in at every 32 inches.
/ AZ ranch #1,394
I totally understand the hot heat you're talking about. Miserable. Watch a lot of shows indoors on tv/internet during the heat of the day.
/ AZ ranch #1,395
The elevation where Bo’s place is located typically doesn’t see sweltering temperatures in the summer. But this year we are sweltering even at elevations above 6,000’.
/ AZ ranch #1,398
You've been busy!!!!
Keeps us posted on the storm, hopefully you'll only get what you need, and there isn't any flooding or damage.
/ AZ ranch
So much for Hurricane Hilary. Like the other Hillary, it was just a lot of hot air. 😄
We got a small sprinkle for a few minutes. Other than that it was just cloudy and cool.
I spent the day on several small jobs in case a storm did materialize. I made a box to slide along the top of the wall that I can dump my mixer into. Cut up some old all-thread to insert as anchor bolts. And hooked up the post hole digger and did a few 4x4 fence posts.
Now it’s time to go out and fire up the mixer!
/ AZ ranch
I got 26 bags mixed before the rains came. My homemade box works really well.
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
2022 Behnke Trailer (A55973)
2022 Behnke...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Bush Hog 287 (A60463)
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
2025 Pabreak Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Pabreak...
