anyone using a WoodMaxx blower??
/ anyone using a WoodMaxx blower?? #161
Do any of you guys use a Kubota BX with a woodmaxx blower?
I only have a BX1860 and am sure that the SB48 would work well. But darn I would like to get a SB60 if I could get away with it. I talked to a guy whom has the same tractor and runs a 50" blower. Said he has not trouble at all running it and said he thought it could run a 60". However, I do not know what type of blower he had. So the fan may not be as heavy duty as the woodmaxx.
The SB60 also says it weighs 695lbs. Not sure if this is accurate, if so then most Kubota BX tractors could not lift it (per the 3pt weight ratings).
Would love to hear your input! I would love to be able to run a SB60 but don't want to get one too big and be unhappy.
/ anyone using a WoodMaxx blower?? #162
Horsmanlife,
That would be way too much blower for your tractor. There's a rule of thumb, that like most rules-of-thumb can be broken, that says 5 hp per foot of blower width. That is conservative, but not by a whole bunch.
If your tractor could lift it, you would still find maneuverability severely impacted. Plus, depending on the snow density and depth, you would need to go extra slow or take partial passes to avoid bogging. The wider blower would end up being no faster or more efficient than the 4 footer, maybe even slower. The only reason I could see getting the bigger blower would be if you were going to move to a larger tractor soon.
/ anyone using a WoodMaxx blower?? #163
Per tractordata.com (TractorData.com Kubota BX186 tractor information) your tractor is rated to lift 670 lb at 24 in out from ends of the lower arms of 3-point. In my opinion that would mean that the sb60 would be too heavy for your tractor. Power-wise, as long as most of your snow is light you should be able to handle it. But if you can't pick it up or keep the front wheels on the ground while it's up in the air that just won't work.
You might be able to use somebody else's lighter 60 inch snowblower, but that one is just too heavy in my personal opinion.
Aaron Z
/ anyone using a WoodMaxx blower?? #164
Your better off buying a 48 inch two stage snow caster from a local dealer and adding 6 inch wings to it using angle iron bent to 30 degrees to make snow gathering wings for it to make it wider as you will have many fewer problems
/ anyone using a WoodMaxx blower?? #165
I will echo the others and say that the SB60 is way too much blower for a BX tractor. I think even the SB48 might be a little on the big and heavy side. There's more than just working width, there's auger size, fan size and weight, etc.
/ anyone using a WoodMaxx blower?? #166
My GC 2410 does a pretty good job of utilizing the SB60. One of the problems is that as you can see in my avatar, the snowblower extends so far away from the tractor. Every time I have a slight incline or decline it stops the tractor. Its a lot of snowblower and weighs a lot-very well made. Comes from China so with the latest tarrifs war im certain the price will go up.
/ anyone using a WoodMaxx blower?? #167
The guys a woodmax are not afraid of putting extra metal in their stuff. My 48" has every part double the thickness of my prior snowblower. Its within a few pounds of maxing my 3 pt. hitch capacity.
/ anyone using a WoodMaxx blower?? #168
I just bought a WoodMaxx SB60 blower for my B2150. I've only used it twice so far but it did a great job on 9" of heavy snow. One thing to consider is its weight (around 700 lbs). I had to add approx. 300 lbs. of front ballast for steering and traction.
/ anyone using a WoodMaxx blower?? #169
I use a 3PT Allied 60" blowrr on my B2150 when the snow is deeper than 6".
For front counterweight, I just pick up a nice big load of snow in the FEL and it has been enough to maintain control/steering.
/ anyone using a WoodMaxx blower?? #170
Yeah, a FEL would be nice!
/ anyone using a WoodMaxx blower?? #171
Hi everyone-
Hope thread is still open. I've noticed 2 things about the Woodmaxx compared to the Allied farmking blowers (only blowers I've seen in stock locally) in the 60" size. The Woodmaxx is much heavier and had a closed gearbox in oil. In the Allied it's open geared until you get into the bigger sizes. I understand the difference physically but what would the practical difference be if anything? Also the Woodmaxx has alot more spec info online. The only 2 things I can compare are weight (Woodmaxx much heavier so I assume heavier built all around) and the Woodmaxx uses heavier gauge chain.
So price is basically a wash for me one seems to be heavier unit and one has benefits of being a local deal. For additional info I have a Kubota B2650 and will be getting for use in Nebraska. So unless things really change (saying this year will be bad) it isn't going to get used like the guys up north use theirs. Maybe get away with the lighter built into to get benefits of local dealer?
Thanks a lot!
/ anyone using a WoodMaxx blower?? #172
I bought an Allied 60 inch blower that came mounted to a B7200 Kubota tractor.
It was a cute set up, and was priced to sell. (Less than I was willing to spend on just the blower to be used on one of my other tractors.)
Trying to load the rig on my trailer, it was quickly discovered that the tractor would not steer! No weight at all on the front end.
Heavy duty blower construction can have it's down sides. I do find the Allied blower substantial and effective. Perhaps too effective. due to it's weight, and in spite of the oversized skid shoes I've fabricated and fitted, there was still a lot of "turf" blown with the early season snow. Last snow year started with a bang here in S. Vt. ;-)
I've since added weights to the front of the B7200, but most recently fabricated a sub-frame to mount a front blower (50 inch) that works Very well.
The 60 inch blower waits for the bigger snows along with the bigger tractor.
/ anyone using a WoodMaxx blower?? #173
Hi everyone-
Thanks a lot!
1. Allied has been building all sorts of farm equipment for a long time.
2. The open gear system is simple to own just like the beater manure spreaders with their oak floors, roller chain drives, open drag chains,
sprockets and bearings to use and repair. A bit stinkier to fix if you have to shovel out 300 bushels of packed bedding/ pen manure to find the broken chain or missing flights-if they are still in the manure spreader. This point is where you hope the broken chain is under the manure spreader.
3. Most important is if you have an Allied Farm King dealer nearby you can get parts sooner or the same day for that matter.
/ anyone using a WoodMaxx blower?? #174
So maybe heavier Woodmaxx would actually be a disadvantage for steering? I do have a loader I will leave on. Can throw weight in there or get a bucket of snow if needed.
/ anyone using a WoodMaxx blower?? #175
Thanks.It looks like all the John Deere dealers carry Allied Farm King and and here there is a John Deere dealer in about every town over a few thousand people.
So the open gear is just one of those deals that it may not last as long but makes for a simpler system? I looked in the manual to see how it's lubricated and couldn't really tell. Do you oil the chain itself?
/ anyone using a WoodMaxx blower?? #176
I use "Chain Wax" on both the open chain and the open bevel gears.
Dirt doesn't collect on that lube so much. It's available at most motorcycle shops.
One thing for sure. When it comes time to replace the 90 degree gears or gearbox, I know which is less expensive. By the way, my blower must be 25 years old. The open bevel gears are looking might strong still.
Ice and snow must act as it's own lubrication ;-)
Just don't let things rust up over the off season.
/ anyone using a WoodMaxx blower?? #177
Thanks! I plan on keeping it in my shed when not in use so that should help!
/ anyone using a WoodMaxx blower?? #178
I have the 60" Woodmax on a B21 TLB which weighs 3800Lbs with the BH, and I believe the BH weighs 700 pounds. The Woodmax is 700 Lbs and it is on the 3Pt arms so the weight is further back than the BH (being close coupled to the tractor) and I do notice the weight difference but it doesn't impact the performance.
Two things - the weight doesn't really matter when you are on a hard surface (paved drive like we have) as the skid shoes are carrying most of it, but if you are on soft ground or gravel I can see the weight allowing the skid shoes to dig in more.
I did put UHMW over the skid shoes a bit wider than the metal ones and they work well.
Bottom Line - both will work well, and for your 2650 its a bit lighter than the B21 so I think the Farm King unit would be fine and a little lighter overall.
/ anyone using a WoodMaxx blower?? #179
I have a mahindra 1533 shuttle and am looking at a sb-72. My question is this. The specs on my tractor says the pto hp is 25. The specs on the sb-72 say at least 25 hp. Is anyone else running a sb-72 with about 25 hp? I checked with woodmaxx themselves and the said it would work but you would need to go slow and it would not throw snow as far as a unit paired to more hp at the pto. Just wondering how it would be at the minimum.
/ anyone using a WoodMaxx blower?? #180
Call Empire Tractor and ask for a price on the MK Martin Series 1000 60 inch cut single stage snowblower.
The shuttle shift on your mule will be a perfect pairing for the single stage 60 inch snow thrower and you can
run it at a higher PTO RPM as well. They are made in Canada.
You will be much better off power wise and torque wise as the single stage is more energy efficient and
easier to maintain with no shear pins to worry about and the single stage snow blower rotor rotates at
650-700 RPM as standard and you can change the drive and driven sprockets to increase the snow blower
rotor speed.
Growing up I had an 1967 IHC cub cadet with 12 horsepower and a single stage 42 inch snow thrower and
it had no issues throwing the snow 50+ feet.
The early 1970's simplicity and 1980's wheel horse lawn and garden tractors we had worked very well with
the single stage snow blowers they were equipped with as well.
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
Lot of (18) Hedge / Black Locust Posts (A66408)
Lot of (18) Hedge...
NEW Predator Gas Water Pump (A62613)
NEW Predator Gas...
84in 3in1 Combo Bucket (A65579)
84in 3in1 Combo...
Landhero Backpack Leaf Blower (A66408)
Landhero Backpack...
2014 Ford Expedition SUV (A64557)
2014 Ford...
