Using schedule 40 on rear blade
/ Using schedule 40 on rear blade #1
tjones59
Clarksville, Ohio
2008 JD 2305
Tried using a 2in piece of schedule 40 on my rear blade so I didn't eat up my gravel driveway when plowing snow today. Driveway is about 400ft and I made 4 passes which did amazingly well then when clearing off the parking pad I notice the pipe had split in half. My guess is it's getting brittle. Does anyone know of another way to put a curl on that blade edge so it doesn't chew up the driveway and lasts? I saw a video someone recommend using black ABS but I can't find it in any of the big box stores in 2in x 6ft only 1.5in x 5ft. Appreciate any help.
/ Using schedule 40 on rear blade #2
I use my blade backwards when the ground is real soft, pushing or pulling.
/ Using schedule 40 on rear blade #3
I'm guessing you used schedule 40 PVC? Not schedule 40 black iron?
Turning around can work, or putting a rubber edge like from a horse stall mat can also take the bite out of the cutting edge
/ Using schedule 40 on rear blade #4
Worth it to use iron pipe, even if you have to pay someone with a plasma cutter to cut the pipe. I used a piece of angle iron as a straight edge to cut mine plus welded tabs front and back to keep it on. It's been on there well over 10 years now.
/ Using schedule 40 on rear blade #5
As LouNY has mentioned to you you should try plowing with the blade reversed
as the blades reversed cutting angle will be such that it will not dig in
the ground.
