Chain sharpening difference?
/ Chain sharpening difference? #41
A illustration
/ Chain sharpening difference? #42
Is that a chainsaw, or you just happy to see me ;)
/ Chain sharpening difference? #43
I have an electric bench top chain grinder but prefer to do all my chains by hand.
/ Chain sharpening difference? #45
No, but I would like to see the spreading slow down.
/ Chain sharpening difference? #46
/ Chain sharpening difference? #47
I use the little Stihl and Oregon guides that clip on the file. But even after years of various mechanical work. I still am not consistent from one side of the chain to the other.
Every 3rd or so sharpening, I use one of the Oregon jigs that clamps on the bar. It's still manual sharpening, but I get both sides of the chain sharp consistently.
/ Chain sharpening difference? #48
I have the dealer sharpen after about 5 hand filings. This has been my file guide journey.
Touched up the chain, but pretty inconsistent by angle and side to side
Not much better
Improved angle and side to side consistency, but funky to use
Worked great! Roller helps keep angle consistent
My favorite so far! Part of it is Pferd files are great, built in depth guide and rakers get filed at the same time.
/ Chain sharpening difference? #50
I served a wood patternmaker apprenticeship at Caterpillar in another life. Sometimes wondering over to the metal side of the shop, the journeymen would really watch a wood guy ;<) and offer help! "Everyone strokes a hack saw and file too fast!" they'd say.
I think of those guys all the time when I file a chain. If I get just a little too fast... it skates. Slow the stroke and you'll hear/feel it chooching better. Easier to keep both sides of the chain consistent too.
/ Chain sharpening difference? #51
I get good results with the Pferd. Also have the Oregon electric grinder with a CBD wheel which also puts a good edge on the chain. But for convenience and on the spot sharpening, I use the Pferd quite a bit.
Both of my saws have 18” bars but the MS261 must have a slightly taller bar because the chain has more teeth.
/ Chain sharpening difference? #54
Swap both the bar and chain
/ Chain sharpening difference? #55
What used to drive me nuts when we were sharing files is people who apply pressure on the back stroke. All they accomplish is to dull the file faster.
I get it now, I guess the bar is different between the MS250 and the MS 261 but if you swap both the bar and chain they would work.
/ Chain sharpening difference? #58
Correct. You'll need to verify, of course, but more than likely they both have .325 pitch sprockets.
I’ll update this thread. To recap my MS250 chain always seems sharper than my MS261. I used the MS261 a couple of days ago and it was cutting so-so and then it started curving as it cut. My normal sharpening technique is about 2 passes per tooth. I did 5 this time, it cut great then.
My conclusion is I use the 261 on larger wood that also in this case was a little dirty. It also has a larger fuel tank so it cuts longer on a tank. I just need to sharpen it more often when I notice it cutting poorly. Not exactly earth shattering news to anyone but I initially thought one saw was cutting better for some other reason. Sometimes I also notice it will be throwing good chips but some saw dust mixed in. I assume that just means some of the teeth are dull.
832655 (A61165)
832655 (A61165)
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2016 JOHN DEERE 310L BACKHOE (A62129)
2016 JOHN DEERE...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A63109)
THIS WILL BE A...
2022 John Deere 317G Track Loader (A63109)
2022 John Deere...
