12x16 Shed Sitting on Blocks Needs Attention
/ 12x16 Shed Sitting on Blocks Needs Attention #21
Oh, I forgot to mention this. In Island County WA, which is where I live, a structure is not considered permanent if it is less than 200 square feet and so no building permit is needed. So if I build a shed and put it on pier blocks and don't provide a permanent power connection I don't need a permit. If the shed is on a poured foundation it is considered permanent. If I need lights in the shed I must use an extension cord. I don't know what your county or state requires but the shed your dad built may have been done the way it was because he couldn't wait for a permit. So if you pour a slab or a foundation it may require a permit. Putting the shed on pier blocks is fine from a structural standpoint, you don't need a poured foundation for structural soundness. And pier blocks are way cheaper than a poured foundation or slab.
Eric
/ 12x16 Shed Sitting on Blocks Needs Attention #22
My suggestion was aimed at leaving in place. Might want to double check with the building code people, sometimes ”portable“ buildings are ok and not taxed. May be why dad built it that way to begin with.
/ 12x16 Shed Sitting on Blocks Needs Attention #23
Whatever time you spend jacking it up so you work on the corners/bottom will be well worth the time. Get the corners up, strap them together as others have said. I've played with cable before and it can be more trouble that you expect--or it might work like a charm.
I like the idea of setting it on a better blocking system. Preferably on gravel. If frost in the ground is an issue, be sure that all corners, and any center support (if used) is all on the same soil so it moves together.
/ 12x16 Shed Sitting on Blocks Needs Attention #24
Hey guys,
I was hoping you gentlemen could help me out with a conundrum I am in. So about twenty years ago my father and uncle built a shed, my father tried to get a permit and they turned him down and said he would have to wait. Long story short he couldn't wait because my uncle was here and they were ready to build it. So now I am stuck in this situation with this building sitting up on blocks. The problem is that the building has started 'slipping' off the blocks in the front. The boards are starting to splinter and I obviously need to do something.
I use this building for my equipment like my Ferris that I use to mow. Anyway I am limited on what I can do and was hoping you guys could give me some advice. I have talked to people about putting a slab of concrete down and moving it to the slab. However, the guy I talked to yesterday said there would be a good chance of it collapsing while trying to move it. It is also on 2x6 runners which complicates things further. So I run my Ferris in and out of this building all the time and we are getting close to mowing again so I would love to hear your guys thoughts.
1.) I was thinking about finding a neighbor with a large tractor and having them lift this side of the building putting a 4x4 or 6x4 post behind this area and driving lags or something in it to pull the structure back together.
2.) I was also thinking I may be able to accomplish this with a high lift jack or bottle jack. I have seen more people use bottle jacks so let me know if you guys have recommendations there.
3.) I have a guy that said he may be able to get it on his truck and move it to a slab of concrete that I have not decided on yet. I have also thought about looking for a guy with a mule which is a piece of equipment built for this.
Anyway before this get too crazy I would love to hear your guys thoughts.
I don't know the dimensions of the shed, but you could get probably few more seasons out of it if you can get a good layer of plastic (tarp or whatever) under the whole thing, then if there's enough space, slide some treated 6x6 posts under it from one side to the other to support the floor joists. I had to do that with a 12x12 shed I had with a similar situation as yours a few years ago. It's still standing now.
Good luck.
/ 12x16 Shed Sitting on Blocks Needs Attention #25
Hey guys,
You are on the right tract I use a car roller jack and come along to square it up then set the building
on treated wood for example 4x4 or 4x6. As to permits for a utility building leave the local yo cals take care of their own business and you will take care of yours.
/ 12x16 Shed Sitting on Blocks Needs Attention #26
A few years ago, I had a similar problem in that the bottom foot or so of my wooden shed had rotted but the rest was good. What I did was, I got a my two ton trolley jack and a long bit of timber. I cut the timber the right length to go from the jack to a top corner inside the shed. I then jacked one corner up about 2 inches. The weight being on the trolley, I cut off the rotten bottom of the shed and laid three rows of bricks and nailed a new bit of timber to the bottom of the shed leaving a two inch gap from the bricks. When the cement between the bricks went off, I lowered the shed onto some bolts I had put in the cement. Out jack and then another corner. It's not spot on, one side is about an inch out, but hey.
/ 12x16 Shed Sitting on Blocks Needs Attention #27
I'd love to see the framing underneath, that might make a difference on how/what you do. Can you stick your head and a camera underneath and take some pictures?
/ 12x16 Shed Sitting on Blocks Needs Attention #28
I have a shed just like that,been in Wisconsin for 33 winters, moves every year with the frost but is 2x8 treated all around. I can lift it just fine with a jack under any of the sides but it is almost empty in the middle. Level it out and fix corners, add support under 16 foot sides as well, put more work into this if you want but mine has to be considered temporary so no foundation, just blocks and spacer plates, treated lumber for spacer plates.
/ 12x16 Shed Sitting on Blocks Needs Attention #29
Hey seriously thank you guys. Especially the last three from DaBear3428, ddbackhoe and JPRambo. I am going to try one of these ideas. I especially like this eyelet idea.
So basically you are saying to add two eyebolts at each corner of the building on the under/inner side? Then place the largest washers I can find on the outside of the building, then crank a nut down so they can support the pressure?
So my main questions would be:
1.) What gauge cable should I be looking for?
2.) How do I tighten and crank the cable to pull the structure back?
3.) If you were me and doing this would you lift the building or no?
Regardless I am going to try to get as much out as possible, whatever I do I believe less weight will make it more persuadable.
I have never heard of these Simpsons Strongtie bracket connectors either. They seem like if I could get the structure back they would solve my issue, especially on all sides. The back side I am less worried about because it is only inches off the ground, it is touching the ground in some areas so more worried about rot. I guess doing it on all four sides can only strengthen it.
I used Simpson strong ties to mount the handrail posts when I rebuilt my deck a few years ago. It is a similar idea to the cable idea without the cable. A bracket is mounted to the joist and there is a bolt that goes through the bracket to the outside. As you tighten the nuts on the bolts everything is pulled together. I purchased the Strong ties at Home Depot. Check them out at Simpson Strong-Tie.
/ 12x16 Shed Sitting on Blocks Needs Attention #30
If it were mine, we all have opinions, before i would jack it up I would start by putting a piece of 6x6 or even 8x8 if it would fit up in that corner and use long 1/2” carriage bolts to at minimum hold that corner together. If you start jacking it up first those 2x’s could twist out of there and the entire corner could fall. If it’s 2’ off the ground you have plenty of room to work up under there. I would then jack it up a put solid concrete pad under that concrete block. With the holes in it there isn’t much surface area to keep it from sinking. Read an article once about we don’t use screw to frame when using wood. They either tear out the wood or break because of expansion and contraction. Nails won’t do that. Good luck.
/ 12x16 Shed Sitting on Blocks Needs Attention #31
Pretty much what he said ;- ) Depending on what framing you have underneath it, put some bracing under corner and start jacking it up, won't know until you try. Some of these building that look so solid and heavy will lift right up. Slow and easy, see what happens.
/ 12x16 Shed Sitting on Blocks Needs Attention #32
Eric
The rules are much the same in my township in Central New York. We made a deal with a dealer of Amish-built sheds some seven years ago to get a 10x12 shed for "free" if we allowed him to put a sign on it advertising his business to the patrons of our farm stand. Because it's on skids and is just sitting on top of crushed stone, it's considered temporary and the town assessor wasn't interested in it. But, if we ever put in some kind of foundation and fasten the shed to it, that status will change.
I'd advise the OP to check with the rules of his municipality before doing anything that might jeopardize the shed's current status.
/ 12x16 Shed Sitting on Blocks Needs Attention #33
Hey guys,
I would buy two 6 by 6 pressure treaded posts 14 or 16 foot long plus a few regular cement blocks and a few 4 inch solid cement blocks. Using Four bottle jacks and a sufficient number and combination of the blocks jack the building up a few inches above its current position. The four jack points will be on the 6 by 6 posts that are placed under the building at right angles to the floor joist. Once jacked up place some concrete blocks and maybe small wooden blocks to level out and hold in place as the bottle jacks will not hold pressure very long. Now with the building about 6 inches above its present height dig and pour footers at least at the four corners and maybe four more, one in center of each of the four sides. Now set concrete block to become the permanent supports. If possible fill these blocks with concrete and add some j bolts.
/ 12x16 Shed Sitting on Blocks Needs Attention #34
I have performed this several times for customers. Use bottle jacks with boards under the base to prevent sinking. Run boards across trusses diagonal for more strength and stability. Jack and level. Place additional pillars of solid block. Without viewing the building I cannot advise on moving the structure.
/ 12x16 Shed Sitting on Blocks Needs Attention #35
Call a local house mover, they can safely jack this building up, repair the spreaded rim joists/corners, and set it back down correctly (I wouldn't put pier blocks under the middle of the floor because there is more weight on the edges of the building and later you might end up with a bowed up floor in the center), I would pour a slab and locate the building on it where it is evenly supported throughout the floor. The house mover most likely can lift the building high enough to allow for a slab to be poured and then set the building down directly without moving the location if that is what you desire, or they could move the building over a slab and set it down. Depending upon your building location, you may or may not need a permit, the house mover would know.
/ 12x16 Shed Sitting on Blocks Needs Attention #36
Were it my sHed, First I would tear out the floor. Dig down 4 places for a jack, jack it up and pour or have someone pour what we call a floating slab under it. 8" thick concrete with some rebar in it, Let it float with the frost. Otherwise, need to move the shed to the new floor on the foundation deep enough to get below the frost line. But for what you are putting in it I would definitely put in a concrete floor.,
/ 12x16 Shed Sitting on Blocks Needs Attention #37
Hey guys,
Why not run a 4x6 under the skids from side to side since the skids are supporting the floor frame to support the structure and then fix the corners
/ 12x16 Shed Sitting on Blocks Needs Attention #38
Several considerations here . . .
Building inspector - what they don't know won't hurt you. You are repairing a small, existing structure. A lot depends on the attitude of your building inspector and tax assessor. If you get a permit, that will alert the assessor that something has changed, and they'll come say hello.
If the building inspector is a retired East German border guard and the assessor is his even more evil twin brother, I'd do the repairs on a weekend because they don't work then. I think I'd also take a look at code (online, where you are anonymous) and see what the maximum size of a building can be before a permit is required. 12 by 16 is 192 sf, if the permit requirement kicks in at 200 sf+, go have a good time. If it is less than that (your building is required to have a permit), think about fixing it on weekends, especially holiday weekends because you get an extra day to do the work quietly.
We happen to be exceptionally lucky in this regard. Our building inspector tells you how you can do something, not why you can't. I built a 4,500 sf hangar, he said "It's a BARN, right? Hangars can't be more than 2,500 sf, you built a BARN, right?" "Umm, yeah, you know, you're right, it IS a barn!" (Our maximum size here for no permit is 100 sf unless it is an agricultural structure.)
As to your building itself, after you have successfully avoided any "Imperial entanglements", the idea of carefully jacking up the corner after reinforcing it and then lowering it carefully onto a proper foundation sounds like a good approach. This isn't rocket science. If you think it through and ask for help and advice (as in this group ;-) I think you'll do fine.
One thing you might want to consider is buying a 20 foot shipping container and replacing the wood building entirely. You're in WV so I don't think the termite problem is too bad, here in FL, invasive Formosan termites would eat that building in one summer as an appetizer and then start on your house.
Best Regards,
Mike/Florida
/ 12x16 Shed Sitting on Blocks Needs Attention #39
Don't complicate things. Your goal isn't to look good it's to keep a roof over you equipment. Jack it up if you must. In any case dig a shallow hole beside each corner, go out to the wood-lot (or lumber store) and get a 4X4 to 6x6 post and above-ground brackets. Dig broad shallow holes adjacent to each corner. Attach the brackets to the new posts, then upright them next to the old corners with the bracket resting on the bottom of the hole. Spike or bolt the post and the corner together. The old construction will hold the new post in place while you put a couple of bags of ready-mix concrete in the hole. Done. Not pretty, but will last another 20 years at least. Been there, done this.
MF
/ 12x16 Shed Sitting on Blocks Needs Attention #40
We moved a 10x12 shed recently. Moved everything out, jacked up each side with bottle jacks and/or automotive floor jack and slid 4x6x16 sliders under (on the flat and perpendicular to the floor joists, in about 6”-8” from each edge), also slid one under the middle for extra support.
We screw cleated a 2x8 board across the front and back of the 4x6’s to block the shed from shifting while being moved.
We then laid 2x8s on the ground across and under the 4x6s every 4-6’ to keep the 4x6 sliders from digging into the ground. We used a small 5 ton excavator to slide the shed about 125’ to it’s new location, jacked each corner up to level, blocked it and set it down leaving the 4x6 sliders as added support for future use.
The shed was easily moved with the small excavator. We did cut four small holes through the floor inside near each corner and ran chain down through and around the joists to hook to the excavator.
I’ve seen cables with turnbuckles strung diagonally from floor to roof to firm and reasonably true up old barn structures to add years of life. It seems like a cost effective method.
The 10x12 (120 sf) no permit required is referenced in the International Building Code which many communities base building permits on.
2021 Boat with T/A Float-On Corp Boat Trailer (A59231)
2021 Boat with T/A...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
Ford 8210 (A60462)
Ford 8210 (A60462)
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
