Taking down some trees for land clearing - how high should I leave stumps for easier removal?
/ Taking down some trees for land clearing - how high should I leave stumps for easier removal? #22
Since you don't have equipment. Cut the trees high enough to see the stump in whatever vegetation applies. Or cut them as flush with the ground as you can. These methods will save you from damaging your tractor by running into one. Then rent whatever equipment you can afford to remove the stumps.
Probably what it will do is cut flush plus nail some flagging tape to the stumps for better visibility until I rent later on.
J.I. Case 430 Utility​
Dimensions
Gas Wheelbase77.1875 inches
196 cm
Diesel Wheelbase78.4375 inches
199 cm
Gas Length129.75 inches
329 cm
Diesel Length131 inches
332 cm
Loader-tractor Length177 inches
449 cm
Loader-backhoe Length264 inches
670 cm
Width77 inches
195 cm
Height (steering wheel)60.5 inches
153 cm
Weight6575 lbs (loader-tractor)
2982 kg
No FEL on mine, but the tires are loaded.
/ Taking down some trees for land clearing - how high should I leave stumps for easier removal? #25
The easiest way to clear land and stumps is to leave a 1-2’ stump. Then come back and push and pile them with a small dozer (D4). Depending on the acreage to be treated, paying for a dozer and operator for a day or two may be the best option to get this project behind you and to start using the land for your desired purpose.
/ Taking down some trees for land clearing - how high should I leave stumps for easier removal? #26
Not real sure what the area is that you want cleared or what your intended use will be. How dense is the growth?
Those 3 questions seem to me to be necessary to determine what you will want to do.
I had about 3/4 acre behind a house I wanted to thin out the < 10” trees and underbrush. I don’t plan to till it or build anything on it. I just wanted to reclaim it to walk through easily, keep it cut back easily and be able to fence it in.
There are some large trees, (oak, pine, sweet gum) from >10” - 36” out there that I’ll leave for now until I get the rest under control and decide what I want to do with it. Lawn, shaded recreation area, ???
Started taking out the < 10” pine and sweetgum trees and leaving ~36” high stumps so they were obvious and I wouldn’t run over them. Possibly that would be enough for some leverage to push/pull them out with the JD 110 backhoe. It really wasn’t.
Even stumps that small left pretty large size holes to fill in. I had a guy with a JD 333G and drum mulcher go over it and mulch the entire area including grinding down the ~36” stumps and some lower that I had cut lower up near the edge of the lawn. I paid for 4 hours @$150 so $600 and the stumps are gone and all underbrush is gone. Some areas were so overgrown you couldn’t walk through before he started.
I think it’s knocked down enough I can keep it under control and can take out a few more trees selectively. The area is fairly level but is not totally flat.
If I was going to plant a garden over the entire area, or build on it I would have needed to do something differently. I may decide to do that, later.
In the future, if I decide to take out some of the bigger trees I could push or fell them toward the rear of the property without concern that they would fall on any buildings.
/ Taking down some trees for land clearing - how high should I leave stumps for easier removal? #27
A D4 is too small of a dozer for any kind of cleaning. You’d have to work on a 12” stump for a few minutes with that dozer. It would take you all day to get a 30” stump stump out with that and you would have a hole big enough to park a semi in. Back when they actually used dozers for clearing they used big dozers and they had pointed blades to split stumps.
/ Taking down some trees for land clearing - how high should I leave stumps for easier removal? #28
We do this all the time with the small firecat D4, and do take out 30” stumps on fire lines. Yes it does make a big root ball hole. We also do it quicker with the D6. But both machines are used in fire line applications. It is generally quicker with the bigger machines, but we don’t use pointed blades. We are generally working in conifer forests and not eastern hardwoods, so I’m sure it requires a bit more muscle on a 30” oak compared to a pine stump.
/ Taking down some trees for land clearing - how high should I leave stumps for easier removal? #29
There’s not a lot of pine around here to experiment with but I could probably push a 12” pine in one pass with my D5. A 12” oak that’s cut flush would be drastically harder.
/ Taking down some trees for land clearing - how high should I leave stumps for easier removal? #30
There’s not a lot of pine around here to experiment with but I could probably push a 12” pine in one pass with my D5. A 12” oak that’s cut flush with the ground would be considerably harder.
Yeah it’s important to leave high stumps. That’s why it’s important to decide what you want before cutting. You either have to leave the stumps or use a mastication machine to deal with flush cut stumps.
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2017 Ford F-350 Flatbed Truck, VIN # 1FD8W3G66HEB73643 (A61165)
2017 Ford F-350...
Great Dane Van Trailer (A61307)
Great Dane Van...
2006 International 4300 Bucket Truck (A61568)
2006 International...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
