WxMan85
- Joined
- Feb 20, 2023
- Messages
- 23
- Tractor
- CASE 580L Kioti CK30
Sorry LS, I had caps lock on and never gave it a thought to change it. Here is the edited version of my first post. Thanks for the info and god bless!!
I have been in a joint custody situation using my father in laws Kioti CK30 with loader and backhoe, (which by the way, you all of this fine forum helped him decide almost 20 years ago to buy), he says hello and thank you for your all’s plethora of knowledge and experience!
I have grown up using this tractor as I dated and then married his daughter, we then 3 years ago moved back close to them and bought 10 acres. I have used it as well as paid a per job price to, use a case 580 Super L from down the road when the project was too big for the CK30 for the last 3 years. The CK30 has 996 hours on it and I don’t want to add another 5 or 6 hundred hours for the next portion of major projects to it. I am replacing all cylinder seals, changing filters and fluids, and tie rod ends and giving it back to its greener pasture home.
Now the big question for me is what in the world do I want and need to buy!?!? As stated earlier, we are on 10 acres, with the possibility in the future to double to 20. My 10 is 60% trees and 40% sandstone boulders with a little shell and dirt mixed in, (not kidding) good ole north eastern Oklahoma land! We are going to clear cut and dig out roots where needed on the fence line which on the 10 acres is about 3/8 of a mile of clearing, build a 40x50 shop with 16’ ceilings (so I need to also be able to fly 50’ trusses), clear cut and remove cedar stumps and a few less than 10” diameter (2-4) trees and stumps for a 30 tree orchard and garden, dig about 750 feet of water lines and electric, cut in a new 400’ driveway, and last but absolutely not least a pond that will be about 3/8 of an acre when it’s full. Now the pond is going to be a cheat by a bit as I am using an already cut in creek that runs diagonally across the property. I will only have to dig down about 5 to 8 feet in half of the pond as the creek has cut the other half out and then build a dam. Still that said, it alone is still a big project and have been quoted 15k for someone to come in and cut it and bring clay in if they cannot locate a pocket of clay on the property, or from when they dig out the pond. They did say it would be closer to 10k if they can locate clay.
So what tractor would you all recommend for all of this work? I don’t really have the money to go over 35k to 40k for something. I have a love for the Kioti brand as I have used one for nearly 20 years, and they have stood behind their product, even out of warranty and that speaks volumes to me!! I have read some about Mahindra and the company and line of products does intrigue me quite a bit. That said I don’t have much knowledge on them other than what I have read about the last few days of researching. I know that I have to lift and move a ton of materials, dig a ton, and build a ton of projects . So lifting and digging are main requirements. The extras would be nice, but those 2 items are the main have to’s for that price. Any and all advice is welcomed and appreciated!
With all of this said, I can possibly purchase a different 580 Super L that is a 97’ open air cab with about 3200 hours that I have known for 90% of its life for about 20k. It just had all new hoses and cylinder seals replaced and fluids changed out. I would have to buy new tires, so that is going to be a couple thousand more on top of purchase price……Thoughts?
