Hooks on FEL Bucket
/ Hooks on FEL Bucket #21
That's so cool. Looks like something I'd do as I fumble around some days.
/ Hooks on FEL Bucket #23
For heavy things like this over 3K cattle guard, two chains on the teeth and two on the back hooked to the top edge:
/ Hooks on FEL Bucket #24
When I got the AF120 I welded a couple of hooks on pretty much the day it got here - that and 2 new sides for the bucket as they had rotted through.
And yes I need to get around to painting it too even though I know it's going to come straight off again!
/ Hooks on FEL Bucket #26
/ Hooks on FEL Bucket #27
I used Bolt On Hooks also, Two on the bucket. My dealer offered to weld them on, but I decided to drill instead. I guess I didn't want to mess with the paint job. Like it matters on the bucket anyway. Larry
/ Hooks on FEL Bucket #28
Welded 3 hooks on a 1/4 plate, and mounted the plate on the top edge of my bucket. One hook in the center, and the outside ones in line with the lift cylinders. Used 1/4 U-channel underneath the bucket top edge as a back-up plate, and grade 8 bolts and tight washers. It isn't going to bend. At least, not with anything my tractor will lift. Lifting a heavy load with a hook on the outboard portion of your bucket can easily tweek your loader frame. It will also get the rear wheel opposite the lifting hook up in the air. Have done that even with my configuration. That can get exciting, and make you lower that load in a hurry. Learned to spread out the load side-to-side evenly using at least the 2 two outboard hooks.
Did they come with a plate to backup under the bucket? Some buckets are kinda thin on AG tractors so they tend to distort when working the hooks hard. Especially when mount far from the welded ends.
Yes they did come with backing plates.
/ Hooks on FEL Bucket #31
I just switch to my forks if I have to chain something to the FEL. A lot safer for me and I wont tweak the bucket any more than it already is plus I have a dozen different spots to hook to.
/ Hooks on FEL Bucket #32
Just remember when "shopping" for Bolt-On or Weld-On hooks, we have the ONLY forged in the USA ones available.
Thanks for the support (y)
/ Hooks on FEL Bucket #33
Havent yet and been doing it for 40 years
Your environment is not as rough as it is here. I put a hole in the center and put a hitch ball so we could use a gooseneck trailer in a chicken house. Never thought they would tie a chain on it. Bucket is bent.
/ Hooks on FEL Bucket #34
Bobcat came with slots that fit a chain nicely.
/ Hooks on FEL Bucket #35
Very cool Doughknob, first time I’ve seen slots like that!
Mike
/ Hooks on FEL Bucket #37
Mu Kiotii came with holes already in the bucket. I have a welder but Im not good enough at it yet so I use this, one set on each side of the bucket. Works great. If anyone is interested here is a link to the carabiner. Plenty strong enough
  • Locking system: SCREW LOCK
  • Gate opening: 1.22" (31mm)
  • Major Axis Strength: 8992 lbs. (40 kN)
  • Minor Axis Strength: 3597 lbs. (16 kN)
  • Open Gate Strength: 2473 lbs. (11 kN)
/ Hooks on FEL Bucket #38
Carabiners are generally not for hoisting or lifting. Not near the safety factor. Some Okay for for personal fall protection.
Done my share of down on the farm rigging before learning the importance the right way and right equipment.
/ Hooks on FEL Bucket #39
It was when I was trying to figure out what tractor to get, what add-ons, implements, etc., that I discovered TbN, and asked for advice.
Then, based on what the TbN members advised, I had a list. On that list - bucket hooks. The dealer welded three on the bucket. Used countless times since.
/ Hooks on FEL Bucket #40
I have three hooks. always have always will. Hooks on the side for light work.
hook in the center for HEAVY work. It doesn't do the mechanism any good to reef the heck out of one side.... plus you can get your tractor airborne.
Welded on or bolted on, is the best. I see the guy with the grab hook attached to a hole with some hot link or shackle. I know it works, but it's a bit awkward. Buddyamine did that to a small tractor and it's kind of a pain in the butt compared to a fixed sold mount.
I use two hooks in line with the lift arms, but never lift with just one. Fasten chain to each hook and connect in the center of the bucket. The lift chain drapes in the center of the bucket to maintain balance when lifting, but the stronger sides of the bucket support the weight evenly.
SANDBAG ATTACHMENT (A60736)
SANDBAG ATTACHMENT...
2018 SPORTSTER BUMPER PULL (A60736)
2018 SPORTSTER...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
207272 (A52708)
207272 (A52708)
