Hooks on FEL Bucket
/ Hooks on FEL Bucket #21
That's so cool. Looks like something I'd do as I fumble around some days.
/ Hooks on FEL Bucket #23
For heavy things like this over 3K cattle guard, two chains on the teeth and two on the back hooked to the top edge:
/ Hooks on FEL Bucket #24
When I got the AF120 I welded a couple of hooks on pretty much the day it got here - that and 2 new sides for the bucket as they had rotted through.
And yes I need to get around to painting it too even though I know it's going to come straight off again!
/ Hooks on FEL Bucket #26
/ Hooks on FEL Bucket #27
I used Bolt On Hooks also, Two on the bucket. My dealer offered to weld them on, but I decided to drill instead. I guess I didn't want to mess with the paint job. Like it matters on the bucket anyway. Larry
/ Hooks on FEL Bucket #28
Welded 3 hooks on a 1/4 plate, and mounted the plate on the top edge of my bucket. One hook in the center, and the outside ones in line with the lift cylinders. Used 1/4 U-channel underneath the bucket top edge as a back-up plate, and grade 8 bolts and tight washers. It isn't going to bend. At least, not with anything my tractor will lift. Lifting a heavy load with a hook on the outboard portion of your bucket can easily tweek your loader frame. It will also get the rear wheel opposite the lifting hook up in the air. Have done that even with my configuration. That can get exciting, and make you lower that load in a hurry. Learned to spread out the load side-to-side evenly using at least the 2 two outboard hooks.
Did they come with a plate to backup under the bucket? Some buckets are kinda thin on AG tractors so they tend to distort when working the hooks hard. Especially when mount far from the welded ends.
Yes they did come with backing plates.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2014 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59906)
2014 FREIGHTLINER...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
Blue Diamond 3pt 4' Mower (A60463)
Blue Diamond 3pt...
