Hooks on FEL Bucket
/ Hooks on FEL Bucket #1
Mrsig
Gold Member
Bushnell, Fl
LS MT225 4x4
Got them the other day very easy to install I just had to buy a new 1/2" drill bit.
/ Hooks on FEL Bucket #3
Only have one hook on my bucket and the hole was already there:
/ Hooks on FEL Bucket #7
I reinforced the bucket top edge and installed hooks at ends and center.
I use the ends (corner) if I am lifting something of insignificant weight and lift from the center any heavy objects. When I lift from the center I do not twist my loader frame or tip my tractor.
/ Hooks on FEL Bucket #8
MY center mount ring on bucket is for holding things in bucket... I put a dedicated pulling ring on front of tractor chassis to do serious pulling..... Only negative is access to ring with bucket in the way...
dsc02246-2-jpg.694616
/ Hooks on FEL Bucket #10
I have three hooks. always have always will. Hooks on the side for light work.
hook in the center for HEAVY work. It doesn't do the mechanism any good to reef the heck out of one side.... plus you can get your tractor airborne.
Welded on or bolted on, is the best. I see the guy with the grab hook attached to a hole with some hot link or shackle. I know it works, but it's a bit awkward. Buddyamine did that to a small tractor and it's kind of a pain in the butt compared to a fixed sold mount.
/ Hooks on FEL Bucket #11
Simply made chain slots from 2x2x1/4 angle iron...
slots-3-jpg.684517
bucket-jpg.683638
The advantage of chain slots is that you can run the chain either direction. down behind the bucket provides more lifting power.
I built slots into the frames:
/ Hooks on FEL Bucket #12
Bend your bucket picking up in center. Corner is stronger.
When I ordered my Kioti I asked for THREE hooks on the bucket. They ended up putting only one (center), stated that they're not allowed to put them at the outer ends of buckets (force on one side of the loader or some other such). I finally got a welder and am waiting for the day I'll be proficient enough to tackle this. My B7800 has three hooks on the bucket and I've used them to tug like hell in all sorts of situations w/o ANY problems: the B7800 is just plain indestructible.
/ Hooks on FEL Bucket #13
Get "bolt on" hooks.....
/ Hooks on FEL Bucket #14
/ Hooks on FEL Bucket #15
No biggie. Grind off the paint on the bucket, get a good ground spot, clamp or support your hook with magnetic positioners, 6011 welding rod and 130 amps....takes just a minute.
/ Hooks on FEL Bucket #16
I have 3 hooks on my bucket.
1 on each end and 1 in the middle.
My middle hook is by far the most used (gets used often)
/ Hooks on FEL Bucket #17
Does anyone know if Ken's Bolt on Hooks offers a discount through TBN or to TBN members?
Thanks.
/ Hooks on FEL Bucket #18
I have 2 hooks welded on to the FEL, and 1 hook welded on to the BH, ... all done at the Dealership prior to delivery, when I bought new. Very useful.
/ Hooks on FEL Bucket #20
View attachment 712278View attachment 712279
Used tractor came with one middle hook. I wanted to add some inline with the loader arms. When I put the new hooks on some how I put the first one on backwards - Duh. I decided to put one on backwards on the other side too, rather than cut it off. Thought it couldn't hurt and might be useful. ?? Actually they have turned out to be quite useful. Not only for more lifting power but also for securing odd shaped objects, pulling low from under the bucket, or just to keep slack chain under control.
gg
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2006 International 4300 Altec LRV58 58ft Forestry Bucket Truck (A61568)
2006 International...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2004 PROCO 130BBL VACUUM TRAILER (A60736)
2004 PROCO 130BBL...
