Hooks on FEL Bucket
   / Hooks on FEL Bucket #1
Mrsig
Bushnell, Fl
LS MT225 4x4
Got them the other day very easy to install I just had to buy a new 1/2" drill bit.
   / Hooks on FEL Bucket #3
Only have one hook on my bucket and the hole was already there:
   / Hooks on FEL Bucket #7
I reinforced the bucket top edge and installed hooks at ends and center.
I use the ends (corner) if I am lifting something of insignificant weight and lift from the center any heavy objects. When I lift from the center I do not twist my loader frame or tip my tractor.
   / Hooks on FEL Bucket #8
MY center mount ring on bucket is for holding things in bucket... I put a dedicated pulling ring on front of tractor chassis to do serious pulling..... Only negative is access to ring with bucket in the way...
dsc02246-2-jpg.694616
   / Hooks on FEL Bucket #10
I have three hooks. always have always will. Hooks on the side for light work.
hook in the center for HEAVY work. It doesn't do the mechanism any good to reef the heck out of one side.... plus you can get your tractor airborne.
Welded on or bolted on, is the best. I see the guy with the grab hook attached to a hole with some hot link or shackle. I know it works, but it's a bit awkward. Buddyamine did that to a small tractor and it's kind of a pain in the butt compared to a fixed sold mount.
2011 Ford F-450 Dump Truck, VIN # 1FDTF4GTXBEC82149 (A54865)
2011 Ford F-450...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52707)
2017 CASE IH 580...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
John Deere BD1108 (A50123)
John Deere BD1108...
