New to welding
/ New to welding
I've only been stick welding a couple years so I am pretty new and I remember the problems I had starting an arc. For me there were two things I could do to make it easier. Turn up the amperage for practice to get the feel and relieve frustration. Then try turning it down to measure your improvement.
Now if I need to use very low amps I find starting the arc with the rod tipped at a very steep angle so I use the coating as a spacer so to speak really helps. Soon as the arc starts tip the rod up where you want it.
But practice is the best thing to do.
gg
This was great and really helped!
/ New to welding
Shield Arc I may have had the plug wrong, but I got a chance to practice tonight and made sure the leads were correct. With the above advice by Gordon I tilted my rod my and faintly dragged it and started my arcs much easier tonight! Here are some 6011 & 7014 practice runs flat, 6011 with the stacked look. You pros I'm sure knew that. Also after more practice with 7014 I ran two last beads then quit for the night. I think they looked my best for the 7014.
But, what do you guys see here to help me out!
/ New to welding #123
WOW! Those look really good!:thumbsup::thumbsup:
Now do it like when you're in welding school. Stack each weld half way on top of the other! Do this for a while, then move on to lap welds, and fillet welds.
/ New to welding
That's really good to hear that they look ok! Should I just stick with one rod type for awhile? Or maybe do each like I have, alot of welds with each.?
Also, I ran the 1/8" 7014 from 80-120. The arc was steady but weak at 80 and weld seemed shallow, 100-110 seemed to be kinda a sweet spot, but much more spatter. 80 amps was the last two welds. Does it matter? Also this is 3/16" steel I believe.
/ New to welding #125
Back in welding school, we started out with 6010. Ran 6010 in all positions. Then moved on to 7018. 6010 / 6011 will teach you puddle control. And help you learn how to read the puddle. 7018, and 7014 is childs play to run, compared to 6010 or 6011.
/ New to welding #126
lincoln 225 stick is what i just bought. I have just started back welding since a little time after high school. i have buddies that have always welded and that was the suggestions if i didnt want to go with wire.
/ New to welding #127
Oh, I forgot. Get a 5-gallon bucket of water. Make 2 or 3 welds, then dip the plate into the water to cool the plate off. When the plate builds up too much heat it is hard to control the weld.
/ New to welding
How do these look? 6011 75 amps running the full rod, so I had several stop/starts. Criticism welcome on anything
/ New to welding #129
Those look great! :thumbsup:
Next I would buy some 1/4-inch thick flatbar, and practice welding lap joints, and fillet weld joints. After that, start working on vertical up hill welding. Then overhead welding.
/ New to welding
So this looks good enough to progress forward to that?
/ New to welding
Ok cool! I have alot of 5/16 or 3/8 flat stock that was given to me and what I've been using so far. Can I use that instead of 1/4" for now since it's free and on hand?
/ New to welding #135
When doing a vertical weld are you supposed to start at the top or bottom? My success rate is way better running top to bottom but I was pretty sure that's wrong.
/ New to welding
Did my first repair last night on my utility trailer. Three places were cracked or completely broken. Most everything was flat position, but with the welds curving or cornering on two of the repairs it felt completely foreign changing my weld in flight. They will hold I believe, but didn't feel comfortable or as nice as I want them to be. So yeah, as I knew already lots more practice needed before I tackle other stuff. Just sharing
/ New to welding #137
Depends on the rod and what you're trying to do.
6010, 6011, 6013, 7014 all run pretty well vertical down.
7018 vertical up.
I run vertical down on thin material (under 1/4") if I'm using stick pretty often.
Even on thicker material I'll run first pass down if there's a gap, or it's hard to reach, or I'm uncomfortable and can't see good, etc.
6010 and 6011 are great for this :)
Run in the upper amp ranges for the rod, point the rod up far enough to keep slag at bay.
/ New to welding
I had enough time to get 6 lap welds for practice tonight. This was the last 3, and better than the first. Not near as easy as flat on a piece of metal. School me!
/ New to welding #139
Not bad at all. It will take some time to get the perfect stack of dimes.
Little trick for you. When you get ready to stop, back up just a touch, and push the rod into the puddle some. This will help fill in the crater. An under filled crater is where a crack will start.
/ New to welding #140
I think I need to download the Shield Arc "app".
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
Four (4) R207782 Rear Wheel Weights (A63116)
Four (4) R207782...
Elgin Pelican Street Sweeper (A61568)
Elgin Pelican...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
