Welding 16ga stainless exhaust pipe
/ Welding 16ga stainless exhaust pipe #1
rangerfredbob
Veteran Member
Dayton, Oregon
Kubota L260
I need to make some intercooler tubing for my F350 so I bought a kit of mandrel bent tubing from Amazon, it's 304 stainless and apparently around 16ga thick... so, which method would you use to weld it? I have a welder (Titanium Unlimited 200) capable of scratch start TIG, MIG and spool gun along with a bottle of 75/25 and straight Argon, have a spool of stainless solid wire and some stainless filler rod. I did a little looking and apparently for MIG straight Argon isn't ideal but fine for TIG and some people just make filler rod out of a twisted pair of stainless MIG wire...
So, thoughts? I haven't TIG welded yet but I'm sure I can figure it out, I'm used to stick welding and going slow and have plenty of material to practice on... leaning toward TIG but spool gun sounds easier if it would work fine...
/ Welding 16ga stainless exhaust pipe #2
I am no pro hobbiest. Will need some on the side practice and will want to purge the tube with argon while welding the outside or it will be a mess on the inside. YouTube is your friend
/ Welding 16ga stainless exhaust pipe #4
Never TIG welded before and considering starting with something round, thin walled and made out of stainless…...I wish you luck.
Well, it could be aluminum, round, thin walled! At least with Stainless you can see the temp change before the bottom falls out!
I would suggest that some 16ga stainless be procured and practice, practice practice before starting the project!
David from jax
From what I've heard there's roughly twice what I need in tubing with the kit I got so I have plenty extra... even have some flat plate to practice on first... I wasn't planning on being dumb and jumping in without practice... also not in a hurry, probably jump in around August or in the winter... want to get injectors and other parts on hand before I get that deep.
/ Welding 16ga stainless exhaust pipe #6
Someday I hope to be good enough to do scratch restarts on out of position small dia round tubes and maintain a quality bead.
/ Welding 16ga stainless exhaust pipe #7
TIG for sure. 16ga is going to be a challenge fer sure. I would recommend a foot pedal for better control and easier starts, especially given the thin gage. - If the unit can use one. Learn on something thicker - 1/8" is not bad. Tubing - especially small dia - is a whole 'nuther world too as al3 somewhat indelicately put it. You will want to set up to backpurge or use Solar Flux on the insides to protect the joints.
Not really set up for purging, but we'll see what I can do... unfortunately the welder isn't pedal capable either... we'll see about getting some practice in over the next week or two... rebuilding the transmission is way ahead in importance...
It's 3" tube so it's not super small diameter...
/ Welding 16ga stainless exhaust pipe #9
RFB, might wanna bookmark this page, seems to cover things pretty good -
HTH... steve
Bukit, thanks, that's very interesting and should be helpful, depending on weather and other projects I'll hopefully give it some practice soon. Not an ideal first project but better than aluminum, I don't have the welder for TIG on aluminum anyway, that's why I got the spool gun, that's a whole other bag of worms... my boat does need a swim step though...
It's been near 90F for most of the last week so projects have been slow...
I did have a thought... structure wise and welding wise I think it would probably be a reasonable idea to cut a short sleeve of tubing (say an inch or bit more) to go on the inside of the seams instead of just butt welding then leaving a wall thickness gap for the butt for filler material.
I looked and I have a 2lb spool of .030" stainless MIG wire so the twisted pair should be reasonable for a filler rod I imagine after watching some more video's and such...
/ Welding 16ga stainless exhaust pipe #12
/ Welding 16ga stainless exhaust pipe #14
I much prefer to work with aluminum for cold side plumbing. That said, TIG looks best but you can MIG stainless just fine with regular ER70 wire
I did think about that just didn't want it rusting but I guess there wouldn't be too much in the air pathway with a straight butt weld... I mean it's an old diesel so there's going to be oil in the air from blowby anyway... trying to expand my options for fabrication anyway... Aluminum would have been nicer but stainless exhaust kits were cheaper and I didn't think about it plus even harder to weld but I'm going to try my hand at aluminum welding soon...
Haven't gotten very far on anything related to welding stainless, hopefully pulling the transmission out of the F350 tonight...
/ Welding 16ga stainless exhaust pipe #16
Please don't use twisted MIG wire. Just buy some TIG rod. It is not that expensive and will work much better. You can use 309 TIG rod or 316, it won't hurt to go higher in the number. Scratch TIG tends to pollute your electrode which will then give off light which makes it harder to see the weld. If you can, try laying a tungsten electrode right next to your work. Then do the scratch arc off of the tungsten. This will tend to keep your electrode cleaner. You will for sure get "sugaring" on the inside of the pipe. The term "sugaring" comes from the appearance of the heat affected zone looking like burnt sugar. You cannot avoid sugaring unless the area can be protected with argon. You can certainly MIG weld the joints with pure argon using stainless but it will look like ****. To get good looking MIG welds with stainless wire you need to use tri-mix gas. For your job it may be worth it to use a small cylinder of tri-mix. If you are already good at MIG welding then using tri-mix gas might just be the best way to go. Better welds, less sugaring on the inside of the pipe because the heat will be less. TIG welding stainless is deceptive because stainless does not transmit heat very well. This means that the heat affected zone heats up quickly and stays hot, so less heat needs to be put into the weld. Without a foot pedal you amperage is set to start welding but then you need much less heat. Since you can't control the heat and the metal is relatively thin the weld will get too hot and fall through unless you can move really fast and add rod at the same rate. This is tough to do for a novice TIG welder.
Eric
/ Welding 16ga stainless exhaust pipe #17
stainless steel is one of the easiest metals to weld. If you decide to mig or tig weld the tubing plug the ends and flood the tube with inert gas. You said your familiar with stick welding, you could practice welding some 16 gauge stainless with 3/32 stainless stick rod .
Now that you mention that, I do have a few pounds of small stainless rods that I forgot about... I really need to get all my rods together and in the shop instead of in a pile in the garage...
/ Welding 16ga stainless exhaust pipe #19
A few years ago I found a bunch of new 2" .065 stainless tubing at a scrap yard for $2 a lb. I bought it , then asked a muffler shop to bend it, they said they couldn't. I ended up making a bunch or 15 degree pie cuts and tig welded them together for the exhaust system on my falcon. There were very few places I actually had to use any filler rod, I was able to run a puddle all the way around most of the tubes without any filler . Cool thing about pie cuts is they make really smooth tight turns real easy.
/ Welding 16ga stainless exhaust pipe #20
Did you ever do the welding? Some stainless alloys are very easy to weld. I liked your idea to sleeve instead of just butt weld. BTW, almost any type of welding will work with stainless. I use oxy/acet and start with some spot welds just to hold all into position and then either add rod if it is flowing well or else switch to hi-nickle bronze rod for making the joint stronger and as a filler.
Sleeve it appropriate to the geometery. I've never had luck sleeving bends so I try to put the joints elsewhere.
