Welding 16ga stainless exhaust pipe
   / Welding 16ga stainless exhaust pipe #1
rangerfredbob
Dayton, Oregon
Kubota L260
I need to make some intercooler tubing for my F350 so I bought a kit of mandrel bent tubing from Amazon, it's 304 stainless and apparently around 16ga thick... so, which method would you use to weld it? I have a welder (Titanium Unlimited 200) capable of scratch start TIG, MIG and spool gun along with a bottle of 75/25 and straight Argon, have a spool of stainless solid wire and some stainless filler rod. I did a little looking and apparently for MIG straight Argon isn't ideal but fine for TIG and some people just make filler rod out of a twisted pair of stainless MIG wire...
So, thoughts? I haven't TIG welded yet but I'm sure I can figure it out, I'm used to stick welding and going slow and have plenty of material to practice on... leaning toward TIG but spool gun sounds easier if it would work fine...
   / Welding 16ga stainless exhaust pipe #2
I am no pro hobbiest. Will need some on the side practice and will want to purge the tube with argon while welding the outside or it will be a mess on the inside. YouTube is your friend
   / Welding 16ga stainless exhaust pipe #3
Never TIG welded before and considering starting with something round, thin walled and made out of stainless…...I wish you luck.
   / Welding 16ga stainless exhaust pipe #4
Well, it could be aluminum, round, thin walled! At least with Stainless you can see the temp change before the bottom falls out!
I would suggest that some 16ga stainless be procured and practice, practice practice before starting the project!
David from jax
From what I've heard there's roughly twice what I need in tubing with the kit I got so I have plenty extra... even have some flat plate to practice on first... I wasn't planning on being dumb and jumping in without practice... also not in a hurry, probably jump in around August or in the winter... want to get injectors and other parts on hand before I get that deep.
   / Welding 16ga stainless exhaust pipe #6
Someday I hope to be good enough to do scratch restarts on out of position small dia round tubes and maintain a quality bead.
   / Welding 16ga stainless exhaust pipe #7
TIG for sure. 16ga is going to be a challenge fer sure. I would recommend a foot pedal for better control and easier starts, especially given the thin gage. - If the unit can use one. Learn on something thicker - 1/8" is not bad. Tubing - especially small dia - is a whole 'nuther world too as al3 somewhat indelicately put it. You will want to set up to backpurge or use Solar Flux on the insides to protect the joints.
Not really set up for purging, but we'll see what I can do... unfortunately the welder isn't pedal capable either... we'll see about getting some practice in over the next week or two... rebuilding the transmission is way ahead in importance...
It's 3" tube so it's not super small diameter...
   / Welding 16ga stainless exhaust pipe #9
RFB, might wanna bookmark this page, seems to cover things pretty good -
HTH... steve
Bukit, thanks, that's very interesting and should be helpful, depending on weather and other projects I'll hopefully give it some practice soon. Not an ideal first project but better than aluminum, I don't have the welder for TIG on aluminum anyway, that's why I got the spool gun, that's a whole other bag of worms... my boat does need a swim step though...
2023 JOHN DEERE 8R340 LOT IDENTIFIER 206 (A53084)
2023 JOHN DEERE...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
Adams 6T Fertilizer Spreader (A53472)
Adams 6T...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2023 JOHN DEERE XUV590M LOT IDENTIFIER 27 (A53084)
2023 JOHN DEERE...
