New to welding
/ New to welding
I talked with Mark last week and he said the 200ST on 110v should run any 3/32 60** & 70** but some would be iffy for 1/8 except the 6011 he said it would run ab1/8" rod. I also believe he said on a 30a breaker for 110v but don't hold me to that.
/ New to welding
My new welding table :D. A little sanding across top of the table and it's good, especially for free!
/ New to welding #103
I'd take that table!. Nice way to get started.
/ New to welding #105
Add me to the "I like the table" list!
Ironically that button is available for PURCHASE from Amazon.com
/ New to welding
Thanks guys. I put some paint remover gel on it this morning, paint should be ready to pressure wash off this evening. Yeah I know, I'm cheating. Lol
/ New to welding #107
Nice table. I need to start hanging around the scrap yard.
/ New to welding
Question for you guys, I'm taking off all the paint from the top & sides of the table but the bottom of the table is painted as well. Do I need to remove it or is it ok on the underside? Not going for beauty, just function here.
/ New to welding #109
Not sure I would have even taken the paint off the top. If you're worried about the paint burning while welding you could throw a piece of diamond plate upside down on the table and tack it. Or buy a hunk of 1/2" to tack on. If it was mine, I'd use the crap out of it just like it was.
/ New to welding
Table is under the shelter & leveled. Now I just need to mount my vise and my welder then run some welds! Welder comes tomorrow.
/ New to welding #111
with those legs i think with some diagonal bracing to all 4 legs you will have a much sturdier table. also some sort of a shelf under it would give you strength and a good place for a few clamps brushes and hammers etc. i wouldnt want to keep any electrical tools under there for fear slag and sparks get in the motor.
/ New to welding
Yeah they had to cut the braces loose to remove it from the frame it was attached to so soon as I feel confident in my welds holding I'm planning to re brace it and add a shelf. Good idea on the power tools, because I saw someone with there's hanging under the table and thought it was a neat idea to add to mine, won't now since you brought that up. Thanks
/ New to welding #113
Re-purposed hand trucks - this one has a power strip tie-wrapped to the back, so just ONE extension cord needed - looking at your situation, you might wanna relocate the axle to use bigger wheels (same for me, just haven't got around "tuit" yet); 13" are MUCH better)
piece of 1/8" FB lets MOST side grinders just slip over it and hang. For transport, I just grab the whole bundle of power cords somewhere near the middle and hang it up over the hand truck handle... Steve
BTW, as shown these can be a little tippy - I later put a couple of those rectangular buckets kitty litter used to come in, moved clamps down to those - improves balance noticeably - the OTHER advantage: easy to move those "too portable" goodies back into secure storage when yer done...
/ New to welding
My first set of casualties.... Lol. Oh and my first weld after i finally kept the rod from sticking.
/ New to welding
Ran these after the first weld them had to quit so I can hit the road. Couldn't resist a few minutes with it first though :). Getting the arc started kicks my tail.
/ New to welding
These were 1/8" 6011's ran at 70-95 amps. Should I have tried hotter for it to arc and not stick easier?
/ New to welding #117
Did you put the ground lead in the 6010 port on the welder?
I really like Hobart's 335A 6011.
/ New to welding
SA, that's actually a really good question, and gives me hope I had it hooked up wrong. I was between packing when it was delivered & I remember deciding between 3/32 7014 or 1/8 6011 after my leads were hooked up. We'll see when I get in Sunday or Monday I'll be sure to hook the leads up correctly and see if it gets going easier. I do know after I got the weld going it was easy to keep it going, it was just getting it started! But I can see the addiction, watching the Puddle and the arc digging in like I've watched videos of and read about. Pretty cool stuff!
/ New to welding #119
I've found with my PowerArc 200ST. ESAB's 10P-Plus 6010, and ESAB's Acclaim 7018 run the best.
When running 6010, or 6011 make sure the ground lead is in the 6010 port on the welder.
/ New to welding #120
I've only been stick welding a couple years so I am pretty new and I remember the problems I had starting an arc. For me there were two things I could do to make it easier. Turn up the amperage for practice to get the feel and relieve frustration. Then try turning it down to measure your improvement.
Now if I need to use very low amps I find starting the arc with the rod tipped at a very steep angle so I use the coating as a spacer so to speak really helps. Soon as the arc starts tip the rod up where you want it.
But practice is the best thing to do.
gg
