Popgadget
Elite Member
HANDLER 210 is on sale at Tractor Supply, that is only 25 minutes from me.... will go check it out.
Our tractor supply stores have welding gas bottles that they exchange.
Look at PrimeWeld
At 58 bucks each or 3 for 68 bucks, it cannot be much of anything useful.@5030
Yeah ... looks more like a self-feeding soldering iron? but claimed to be "industrial laser welder"? on "flash-sale" sale today ... 3 for $68 ... lol
Interesting comment. Neither of the Hobart's I own have ever had a wire feed issue, in fact both have the original liners in the guns, only the tips and nozzles have been replaced, numerous times. I do run inline wire wipers on both machines however. If I remember correctly, both machines are about 20 years old and of course transformer based. Back then, IGBT's weren't even invented yet.I've owned two MIG welders, and used many more. It seems to me the weak link in the very concept of the mig welder is the feed system. I've had more wire feed issues in more MIG welders than I can count, but really nearly zero troubles of any other type or form.
So when looking at these cheap Chinese wire or MIG welders, my first quesitons would be directed at their wire feed mechanism. If that fails to work, then who really cares if it's IGBT or transformer-based?![]()
I don't have as much trouble with regular wire, but back when I was running mostly flux core, yeah... lots of trouble. I think the feed wheel design that Hobart runs for flux core isn't as reliable as their regular feed wheels. Also, I think the liner was badly worn on one of the machines in which I was running flux core for many years. I ended up replacing the liner (and of course the feed wheel) when I switched that machine over to regular wire, and it's better now but still never trouble-free.Interesting comment. Neither of the Hobart's I own have ever had a wire feed issue, in fact both have the original liners in the guns, only the tips and nozzles have been replaced, numerous times. I do run inline wire wipers on both machines however. If I remember correctly, both machines are about 20 years old and of course transformer based. Back then, IGBT's weren't even invented yet.
Yawn ...I might add that I own numerous welders, both TIG, MIG and SMAW, a Lincoln engine drive ac/dc stick welder with a Lincoln HF scratch start TIG box though I don't use it. How about 2 Hobart 210 MIGS (old style transformer machines), both running solid wire and 75-25 shielding gas plus a HF ProTig machine running a CK Series 20 flex head water cooled torch as well. Has an Everlast water cooler on it. I don't scratch start TIG ever because it causes weld inclusions. I'll list everything for your absorption...
Nodding off now... I'm bored.2HF plasma cutters, 1 65 1 45
HF ProTig with water cooled torch with Everlast water cooler
2 Hobart wire MIGS with shielding gas
Victor O/A setup with bottles of course
I told you, mines bigger... Now put yours away now, everyone is laughing!2 vertical mills (Bridgeport, 1 versa Trak)
LeBlond servo shift toolroom lathe
South Bend floor lathe (restored)
Kent toolroom surface grinder
Dake hydraulic arbor press (25 ton)
Driese & Krump 30 ton hydraulic press
Shop Saber Sidekick 10 plasma table
..and of course all the associated tooling that goes with them. Both my employees are also certified AWS.
Hmmm I'm going to turn you off as this conversation is only proving your not the brightest bulb in the pack...We do short run machining as well as light and heavy fabrication and I'm proud of what I own and been in business for over 20 years now.
I also hold patents on a number of motorcycle related accessories that we sell worldwide.
Put that in your pipe and smoke it...
Yes, i definitely did. I bought a spool when i bought the welder.Have you even tried it? That one lot that was an issue was like 15 years ago now, I'm pretty sure that's all out of the stores... I've used Lincoln, Forney, two versions of HFT and assuming you have an idea of how the welders work you can work around it... one of the main issues is on the A/C cheapo fulx core welders they have too much voltage for .030" wire and weld like garbage with that, switch to .035" wire and use the settings wrong (change wire speed for temp, more wire colder which is backward) and you can deal with it...
I have no problem with flux core, I use it here and there, was my primary light welding setup for many years, gotta get my bottle swapped since it's almost empty...
