New to welding
/ New to welding
Man oh man, that last picture of the weld with the cup brush beside it. You are doing great!:thumbsup::thumbsup: What a fast learner you are! :cool2::cool2::cool2:
Thanks, definitely a big learning curve on this.
Question, when I run my 7014 over the 6011 I'm having very slight undercut on the edges of the plate. I went up & down on my amperage, tried pushing & pulling the arc, slight weave, etc... I can't seem to completely get rid of it. For the most part you can't drag your fingernail and catch the gap, but it's there and bugs me. Any recommendations?
/ New to welding #162
When you weave, hold just for a split second on the edges / toes of the 6011 weld. That should let the undercut fill in. If that doesn't work. Turn the AMPS down some.
/ New to welding
Ran some 3/32 7018 tonight, wow is all I can say!!!
Question for you guys, I grinded and re welded my welds 2-3 times per side, 3/8" steel. I can notice a very very slight bow in the plate. Is the steel still good to use for a inner brace? Or has rewelding it to my satisfaction possibly weakened the steel?
/ New to welding #165
Its draw it up. It will happen. Weld on the back side, and it is likely to draw it back in line. Keep in mind this stresses the metal.
/ New to welding #166
As Mark said, you can weld on the back side. And let it cool, to draw it back. Or if you have a torch, you can heat the back side, and spray water on it. To draw it back straight.
/ New to welding #167
Question guys, what is a good convenient height to have the top of your work bench table for welding? Compared to your body?
I can't remember the exact measurement but my welding table is about 36" high. I have an old counter high bar stool I use to sit on for the stuff close to the table. I'm 6' tall.
/ New to welding
Good to know, thanks guys. I think I'm going to just strike this plate up as a learning curve and cut/weld a new one in. It was good practice being my first V Grove butt weld though.
Question, if I ran a pass of 6011, could I cap it with a pass of 3/32 7018? Or would I be better with 1/8" 7018? It's 3/8" steel, I'm butt welding the 3/8" flat stock together, then fillet welding it to the 1" steel 3pt arm. I already have 3/32 7018 is why I ask. Also have 1/8 7014 but I ran some welds with the 7018 and man does it lay down NICE. No issues with undercut using the 7018 either and I ran them as hot as turning the rod cherry red by half rod burned.
/ New to welding #169
Sure, pipe is welded every day that way. Well, pipe welders use 6010 for the root pass, and for the hot pass. Then fill and cap with 7018.
Using 3/32-inch 7018 you will find you don't travel very far, is all.
/ New to welding #170
Question....what does the Dedicated E6010 port do on the PowerArc 200ST versus most other machines that have no such port?
/ New to welding #171
For a total novice, or someone with limited experience (like me), this is possibly the best educational video I have seen on the 創et.
Steve Bleile Stick Welding 1 - YouTube
Also, it is the only video about welding I have seen where one can actually see the weld puddle and not just a massive flare of light and some smoke.
He has other videos about TIG, MiG, Oxy , etc.
/ New to welding #172
Mark can give the technical answer. But I think it changes the voltage.
/ New to welding #173
Guessing the port hooks to higher open circuit voltage leg which is needed to run the cellulose flux rods 6010 and 6011.
/ New to welding #174
Basically yomax is right. It also runs through an extra/separate inductance coil and runs a different internal setup and arc force and hot start programming.
/ New to welding #175
Thanks, Mark....so have the rods changed recently to a different flux or that some inverter welders need the different set-up to run even the old standard rods optimally? 90%+ of my stick welding has been 7018 (some 7014 & 7024) on DC MG or transformer, so I have no recent reference.
More recent welding has been MIG w/CO2, but looking at some of the new portable MIG/Stick combo units in the 160-180 A range for light fabrication and outside equip repairs with fluxwire.
And Welcome Kenlip...another Aussie on the forum....the more the merrier!
/ New to welding
Finally finished prepping the 3pt arm and welding back in new braces. 1st pic 7014, 2nd 7018. I think my fillet welds are getting much better.
/ New to welding #177
WOW! BMan2005 those welds are very impressive!:thumbsup::thumbsup: You are a natural at welding!:cool2::cool2:
/ New to welding #179
I think BMan has been playing with us all along! :confused3: Nice job! :thumbsup:
Well, he HAS been only welding a "few weeks" whilst being mentored by an unnamed member that admittedly has only a "few weeks" experience under his belt.
Nice progress. BMan
/ New to welding
Nice progress. BMan
Thanks guys, learning in leaps and bounds when I start working on a project. It's like I notice or make mistakes more.
My grinder would disagree with y'all. Running two, so one can catch it's breath when I switch out. Lol
Picture I took earlier tacking up a brace i put much lower running across & welding it to the brace running along the arm & to the arm it self. This should in my mind eliminate the weak points that cracked how it was originally designed. Going to put some more in sometime this weekend if I can catch a break.
2014 FORD E-SERIES VAN (A67714)
2014 FORD E-SERIES...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
81021CFL (A64556)
81021CFL (A64556)
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
