? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix?
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #1
docrocky
NW Ohio and SE Michigan
Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
This engine is used on an older EZ rake or Trac vac. I do not know if it is a replacement engine or not. there are no markings on it except the pull cord has SSK and NOK on the handle. I am concerned because the gas cap is marked with a fuel to oil mix of 50:1. The air filter is by a Japanese firm: KOUKENSHA. It has oil ports on the bottom of the engine. I inadvertantly have been running it on regular fuel and then I noted the marking on the top of the fuel cap!!!! I am afraid to ignore or use the 50:1 ration mix.
Any info would be helpful....
Thanks...rockydocky
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #2
Someone replaced the fuel tank filler cap with an inappropriately marked piece.
The engine is a four stroke with oil in the crank case that full fills all lubrication requirements.
But don't forget.. " engines run better and last longer with Marvel Mystery oil in every fill up!"
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #3
what Calg said. Cap looks plastic and the original cap was metal. Good engine though.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #4
Yep, some goomer put a two-stroke fuel cap on a four-stroke fuel tank! Reminds me of people that converted those early GM diesels to gas engines but left the diesel stickers on the fuel filler. :rolleyes:
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #5
Do you see a place to add oil??
I don't know about your engine, but I have a Still FS 90, 4 stroke weed wacker that requires a 50 to one mix. They call their motor a 4 mix.
It has valves just like a four stroke but holds no crankcase oil.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #6
No kidding? Never heard of that. I (and I'm sure many others), would like to see a thread and pics of that. Sounds interesting. :)
Gentlemen: thank you for the quick responses. BUT....the gas tank is plastic and match for the plastic gas cap. Have you encountered a Briggs/S or Tecumseh that has a Japanese air filter? Could this be a Japanese engine? The SKK on the pull start matches a Japanese motor bike company but i could't find any 1 cylinder engines on their web site. The small filter that fits into the top of the gas tank is also unusual to what I have ever seen with B&S or Tecumseh. Any clues here?
Oh, the challenges of the day, week, month and year.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #8
Pull the plug and check compression to tell if it is a two cycle.
There are larger two cycle engines that have a separate crankcase.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #9
I have an old Kawasaki FA210D that has the same muffler and red switch,but the carb and tank are like an old 5hp Briggs.The motor looks the same otherwise.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #10
Pull the muffler and see if there is a valve behind it. I think it is a two stroke myself.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #11
Up until I saw the carburetor, I was going to say 5 hp Briggs also. That doesn't look like a Briggs carb. Maybe a Frankenstein?
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #12
My Stihl chainsaw is a 4 cycle that requires a 50:1 mix. Never have seen such as an engine that large, though.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #13
The engine is Japanese made by Honda for the company who makes the vacuum. The fuel tank (if plastic) has been replaced.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #14
The crankcase on your engine is oil filled according to the sticker regarding oil weights and levels. No mix needed.
Regards
Sean
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #16
Moss,
I have a Stihl pole pruner ... uses the same type of engine (4 mix) ... apparently it's something they came up with to reduce engine emissions and pollution.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #17
grm61
thank's for posting the Stihl link.
as the old saying goes..You learn something new everyday. I have never even heard of the 4 mix.
Regard's
Sean
Gentlemen: Again thank you for your responses. After learning that the engine was possibly as Kawasaki/Japanese built, I then drained the fuel tank and replaced the regular with a 50:1 gas oil mix. She runs more beautifully than before while running on plain regular without the oil mix. Previously it seemed to want to tie up after extended running and stiff when using the pull cord. No smoking either. I'll stay with the gas oil mix.
Thanks Again
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #19
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #20
I doubt it'll hurt a thing running with a little oil in the gas. Back when I was a kid my father had a lawboy push mower. So we always had mixed gas. That gas would get used in everything from dirt bikes to go carts with Briggs engines. Never fouled a plug. Of course back then nobody cared about a little extra smoke in the exhaust. In today's world burning a touch of oil in your gas would set off alarm bells.
Cushman Cart (A59231)
2007 Frienghtliner B2 School Bus (A59230)
2007 Frienghtliner...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56438)
Gleaner N630 Corn...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
CAT 336E (A58214)
CAT 336E (A58214)
