? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix?
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #11
Up until I saw the carburetor, I was going to say 5 hp Briggs also. That doesn't look like a Briggs carb. Maybe a Frankenstein?
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #12
My Stihl chainsaw is a 4 cycle that requires a 50:1 mix. Never have seen such as an engine that large, though.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #13
The engine is Japanese made by Honda for the company who makes the vacuum. The fuel tank (if plastic) has been replaced.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #14
The crankcase on your engine is oil filled according to the sticker regarding oil weights and levels. No mix needed.
Regards
Sean
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #16
No kidding? Never heard of that. I (and I'm sure many others), would like to see a thread and pics of that. Sounds interesting. :)
Moss,
I have a Stihl pole pruner ... uses the same type of engine (4 mix) ... apparently it's something they came up with to reduce engine emissions and pollution.
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #17
grm61
thank's for posting the Stihl link.
as the old saying goes..You learn something new everyday. I have never even heard of the 4 mix.
Regard's
Sean
Gentlemen: Again thank you for your responses. After learning that the engine was possibly as Kawasaki/Japanese built, I then drained the fuel tank and replaced the regular with a 50:1 gas oil mix. She runs more beautifully than before while running on plain regular without the oil mix. Previously it seemed to want to tie up after extended running and stiff when using the pull cord. No smoking either. I'll stay with the gas oil mix.
Thanks Again
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #19
   / ? Identify this 1 cylinder 4 stroke engine that requires 50:1 fuel/oil mix? #20
I doubt it'll hurt a thing running with a little oil in the gas. Back when I was a kid my father had a lawboy push mower. So we always had mixed gas. That gas would get used in everything from dirt bikes to go carts with Briggs engines. Never fouled a plug. Of course back then nobody cared about a little extra smoke in the exhaust. In today's world burning a touch of oil in your gas would set off alarm bells.
207279 (A52708)
207279 (A52708)
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
1408 (A57192)
1408 (A57192)
2014 BOBCAT E32 EXCAVATOR (A60429)
2014 BOBCAT E32...
light tower (A56857)
