Mixing container for 2-stroke fuel
/ Mixing container for 2-stroke fuel #22
I get four stroke mowers for free. Just a little work and can get them running again. Do not care at all how long one lasts. They will run on total garbage fuel, cause they are so primitive.
/ Mixing container for 2-stroke fuel #23
I actually use a tablespoon if I have a bulk bottle of two stroke oil. I printed out a chart for how many tablespoons per ounce. I often buy the little bottles of oil that you dump in a gallon of gas. No mixing involved, just dump it in a gas can, fill and shake a little. Just dump it in a full tank of fuel in your car or truck if it gets a little old.
Does your wife know about you using her kitchen tools to mix oil and gas ?
/ Mixing container for 2-stroke fuel #25
What does everyone use?
Thanks.
Most gas cans (actually all gas cans that I've ever seen) have measurements marked on them. Measuring the gas is easy. Measuring the oil is a little more work, but not by much. One way to do it is to use one of the pre-measured bottles that all of the major chain saw companies sell as a measuring device. Or, you can get clear plastic measuring cups that work for the purpose.
So this is the issue: The gas cans I have are not good containers for measuring gas, not in the quantities I want, a quart to a half-gallon, and certainly not to the precision I think is warranted. Hence the question.
I don't have any issues measuring the oil.
/ Mixing container for 2-stroke fuel #27
Same as others - have used a 2 Gal red plastic gas can marked with a sharpie at the 1 Gal line for 15 years (took it to the station and filled1 Gal). Pour in the oil and add gas - use about 2-3 gal a year.
/ Mixing container for 2-stroke fuel #28
If a quart will work for you the pre-mixed fuels may be an option. Have some Echo Red Armour in quart pre-mixed cans that are very handy. Long shelf life of 2 years after opened. They are more costly than my fuel I mix at home but always try to have 1 or 2 on shelf for convenience
/ Mixing container for 2-stroke fuel #29
So get a half gallon or quart milk jug, fill it from a larger container with a cheap battery pump, and dump it in your gallon can. Then add the correct amount of oil and shake.
Pump is on sale at Harbor Freight for $7.99!!!
/ Mixing container for 2-stroke fuel #30
You can easily measure a half gallon in a one gallon gas container. I'm curious why you're only mixing a quart at a time though? Mix up a gallon and it'll be fine for at least a year or so. If you find that you don't use it in that time, simply pour it in the nearest fuel tank (your car, lawn mower, etc) and mix up a new batch for your saw.
/ Mixing container for 2-stroke fuel #31
I’m just guessing here but the op must be mixing the gas from a larger container. When I do it I’m filling the can at the pump I just stop when the pump says I hit the amount I want. None of my gas cans have a mark for the amount of fuel except one I just bought, and it’s pretty close. Most of my diesel cans have a mark but it’s hard to see the amount of fuel in the can.
/ Mixing container for 2-stroke fuel #32
I understand not wanting to mix up 5 gallons of fuel at once, if you're not using it in a reasonable couple of weeks. But a quart?!? That's literally one tank full on my favorite chainsaw, and I can go thru a few tanks in just one day of cutting.
I know folks like to complain about the new gas tanks, and for filling mowers and tractors, I agree they're too slow when filling the zero turn or tractor. But I love the No Spill for filling chainsaws, as the button lets me top off the saw perfectly without any spills.
Only gripe I have about them, for this application, is that the spout diameter is a little tight on some Husqvarna and older Echo saws. No problem with Stihl though, they have more reasonably sized filler caps.
/ Mixing container for 2-stroke fuel #33
1.25 Gallon Gasoline Can – No-Spill These cans work great and have marks for the quantity of fuel in the jug. It's easy to pour from a larger container into one. Anyway, easiest way to do it is just fill the can like you do and mix in the correct amount of oil. Use it up in a year or two, if it's non ethanol. If you can't use it in the saw, use it in something else.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2006 Takeuchi TL150 Compact Track Loader Skid Steer (A59228)
2006 Takeuchi...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
1981 Mack DM492S T/A Flatbed Fuel Transport Truck (A59230)
1981 Mack DM492S...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
