MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,359
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Fogs for mosquitos, too.I run the old stuff through the four stroke lawn mowers. A little smoky... so what.![]()
Does your wife know about you using her kitchen tools to mix oil and gas ?I actually use a tablespoon if I have a bulk bottle of two stroke oil. I printed out a chart for how many tablespoons per ounce. I often buy the little bottles of oil that you dump in a gallon of gas. No mixing involved, just dump it in a gas can, fill and shake a little. Just dump it in a full tank of fuel in your car or truck if it gets a little old.
I wash it after I use it!Does your wife know about you using her kitchen tools to mix oil and gas ?
Most gas cans (actually all gas cans that I've ever seen) have measurements marked on them. Measuring the gas is easy. Measuring the oil is a little more work, but not by much. One way to do it is to use one of the pre-measured bottles that all of the major chain saw companies sell as a measuring device. Or, you can get clear plastic measuring cups that work for the purpose.What does everyone use?
Thanks.
So this is the issue: The gas cans I have are not good containers for measuring gas, not in the quantities I want, a quart to a half-gallon, and certainly not to the precision I think is warranted. Hence the question.Most gas cans (actually all gas cans that I've ever seen) have measurements marked on them. Measuring the gas is easy. Measuring the oil is a little more work, but not by much. One way to do it is to use one of the pre-measured bottles that all of the major chain saw companies sell as a measuring device. Or, you can get clear plastic measuring cups that work for the purpose.
If a quart will work for you the pre-mixed fuels may be an option. Have some Echo Red Armour in quart pre-mixed cans that are very handy. Long shelf life of 2 years after opened. They are more costly than my fuel I mix at home but always try to have 1 or 2 on shelf for convenienceSo this is the issue: The gas cans I have are not good containers for measuring gas, not in the quantities I want, a quart to a half-gallon, and certainly not to the precision I think is warranted. Hence the question.
I don't have any issues measuring the oil.
So get a half gallon or quart milk jug, fill it from a larger container with a cheap battery pump, and dump it in your gallon can. Then add the correct amount of oil and shake.So this is the issue: The gas cans I have are not good containers for measuring gas, not in the quantities I want, a quart to a half-gallon, and certainly not to the precision I think is warranted. Hence the question.
You can easily measure a half gallon in a one gallon gas container. I'm curious why you're only mixing a quart at a time though? Mix up a gallon and it'll be fine for at least a year or so. If you find that you don't use it in that time, simply pour it in the nearest fuel tank (your car, lawn mower, etc) and mix up a new batch for your saw.So this is the issue: The gas cans I have are not good containers for measuring gas, not in the quantities I want, a quart to a half-gallon, and certainly not to the precision I think is warranted. Hence the question.
1.25 Gallon Gasoline Can – No-Spill These cans work great and have marks for the quantity of fuel in the jug. It's easy to pour from a larger container into one. Anyway, easiest way to do it is just fill the can like you do and mix in the correct amount of oil. Use it up in a year or two, if it's non ethanol. If you can't use it in the saw, use it in something else.I’m just guessing here but the op must be mixing the gas from a larger container. When I do it I’m filling the can at the pump I just stop when the pump says I hit the amount I want. None of my gas cans have a mark for the amount of fuel except one I just bought, and it’s pretty close. Most of my diesel cans have a mark but it’s hard to see the amount of fuel in the can.
