Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience
/ Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #61
I actually prefer the Autocut head on my Stihl over the Feed Speed I have on my Maruyama for two reasons. The Stihl holds more line and I like the larger diameter of the Stihl head. A lot less line flutter at low rpm’s as well in heavy brush. Feed speed is easier to string up but I have to more often.
/ Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #62
Well I'm used to the Autocut on my Stihl KM110 as you load the two lines, then just push the lines through the slots and snap in place.
/ Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #63
Interesting comments, how much line do you usually load into your Stihl heads ? I usually do about 12 feet but it definitely seems like a lot more line could easily fit.
The comment about line fluttering at low rpm’s with speed feed head is also interesting I don’t remember anyone ever mentioning that before.
/ Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #64
The manual for my auto cut head says it should take 7m (23') of .105 line per strand but there's no way that much fits. I do about half of that.
/ Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #65
I measure with my arms, I'm 6"2" so my arm span is close to that and I pull 4 arm span lengths off the spool each time so I'm putting about 24' of .105" line in my Stihl Head. My Speed feed I can fit about 15' of .095 in.
/ Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #66
Weird that so much fits. Maybe it's because I'm using 0.105 Deere square line that it doesn't fit as well?
/ Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #67
Yeah, Im sure different shape lines could affect that. Im running Echo Black Diamond in my Stihl and Rotary Vortex in my Maruyama so neither are round though.
I don't find any issue with the run time, I have both the two of the AK20 and five of the AK30 batteries I use them in a string trimmer and blower. I did not buy the AK20's they came with the tools, I much prefer the AK30 batteries. I can get anywhere from 30 minutes to an hour depending on use. They do tend to run down about the time I am ready/need for a short break, usually when I am as far away from the other charged batteries as I can get.
As for cost of the batteries, I find them in line with other battery tools which are all costly.
John that is good to hear of the run times you are seeing. I will get a battery Powerhead and some batteries soon I am sure just to see how they work out. The good thing is with the Stilh Kombi system the attachments can be used on either. Since I do not golf i can use those funds to buy more tools than I truly need. (It must be a illness I have I bet golfing is less expensive)
/ Sthil Commercial Line Trimmers with 4 Cycle engines (still require 50:1 fuel/oil mix) - any experience #69
I have a Kombi 130 from shortly after they came out. Rock solid.
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Crown RM6025-45 Stand-On Electric Forklift (A59228)
Crown RM6025-45...
DEUTZ MARATHON...
Westfield Conveyor (A61307)
Westfield Conveyor...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
44052 (A55852)
44052 (A55852)
