Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #1,101
Dang... I knew I should have taken a picture. There are four pins on the mower itself that are holding two levers. Those two levers connect to the lifting arms. If I leave both pins in, the levers can not move up or down and the mower never touches the ground. If I take one pin out of each lever, the mower will now touch the ground.
My question is if this is okay to remove the pin, and just have one per lever on the mower.
I think you are describing the clevis pins that hold the lower 3PT arm attachment points. See photo below. They are at the extreme left side of the photo.
I don't know why your mower won't touch the ground but it sounds more like a problem with your tractor 3PT lower arms not going low enough. You can see that on my tractor the mower is on the ground and the pins are attached normally (2 clevis pins installed). The little tabs holding the Cat 1 pin can jiggle a bit but don't really move. Are you sure you don't have a stop or something like check chains preventing the 3PT arms from lowering?
/ Let's talk flail mowers #1,102
Okay I got my new Caroni fail mower attached to my LS 4047 tractor, but ran into an issue with the 3pt attachemnt. The pins for the lifting arms are attached to the mower with two pins. Problem is I have to pull the front pin in order to get the mower to touch the ground. It looks like this should be fine, but I wanted to see if I am makinga big mistake... Any advice is appreciated
Can you post a picture or two ?
I got the side shift kit with mine and don't have a problem with it on any of my tractors.
I still have all the parts for the non-side shift assembly, so I might be able to understand what you are running into.
I vaguely remember some "opportunities for incorrect assembly" due to slightly ambiguous instructions/diagrams, but please post pictures.
/ Let's talk flail mowers #1,103
Island tractor, thank you for the picture, and you nailed what I am talking about. I am going to try o elongate my lift rods to see if I can make up the difference. Between and Italian mower and a Korean tractor, these instructions are far from clear... Why do I get this bad feeling that this is only the beginning of my issues with this combo!
I guess I am still wondering why the those tabs (with the two clevis pins) are in a heavy duty housing that looks like it is designed to allow movement.
/ Let's talk flail mowers #1,104
OK, I now see the 2 clevis pins at each lower arm connection point; forgot it was set up like that. You should definitely not have to remove one of those pins to get the flail to sit right, including lowering it all the way onto the ground.
You need to adjust your tractor's 3 point hitch arms. Look at the back of your tractor where the 3 point hitch arms pivot. Now look out along the arms to where the vertical (or near vertical) rods lift those arms. Somewhere around there on the lift arms should be a way to adjust them, so that the height range your 3 point hitch can travel now can be lowered. After making this adjustment, your 3 point hitch won't go as high, but it will go lower. And if you need to put it back for another implements, you can do so. I had to do this to get an auger to drop all the way down. Before adjustment, the auger would only dig about a 1-foot deep hole, due to the 3 point hitch being adjusted to a higher range position. After adjusting it down, the auger would dig a 3' deep hole, maybe even a little deeper than that. A small adjustment of the 3 point hitch arms can make a big difference in how high or low your 3 point hitch can go.
/ Let's talk flail mowers #1,105
Don't worry about being alone in having trouble setting things up. I had the topping lift structure mounted backwards for a year before I figured out it was wrong!
I suspect that the clevis pins are used (which makes the tabs free to wiggle just a little) because it allows quicker set up when you choose to offset the mower (note there is a second set of recepticles). However, as the topping lift structure is secured by about a dozen or more bolts, you need a wrench and socket set to move it anyway so I don't understand the benefit of making only the tabs easier to move. I suppose it might be possible to leave the topping lift structure in place and just quickly move the tabs but I've never tried that. I suspect that is what the hydraulic shift kit does (functionally) as I am pretty sure the lift kit doesn't move the whole topping lift structure. But, this begs the question of why there are two settings for the topping lift structure.... Who knows?
In any case, I think the solution to your immediate problem is with the setting of your lower control arms on the tractor. Bebbington is on the right track.
/ Let's talk flail mowers #1,106
Finally have it up and running... I am having a blast with this mower so far!
/ Let's talk flail mowers #1,107
you CAN run with only one pin. it is setup like that so the mower can articulate side to side independantly of the tractor. I.E. one rear tire drops in a hole and with it pinned rigid the mower will either dip too or lift the other side up. with one pin it can "float" indepandantly of the tractor.
My Frontier RFM is set up similarly.
/ Let's talk flail mowers #1,108
Ah, flail mowers.
Flail mowers, My favorite subject.
Hello Island Tractor, Are you getting any snow yet? Things look rather wet for Boston.
I believe the two settings are for the front mount option which would be lower in use than the rear mount due to the lower ground clearance for the front mount with the P.T.O. shaft under the front axle of a standard row crop tractor with a mid or front mount/flywheel P.T.O., option.
/ Let's talk flail mowers #1,109
Welcome to the Flail Mower Nation.
Only 17,993 mowers to go.
_________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
/ Let's talk flail mowers #1,110
I bet you were real happy whacking the weeds close to the water line.
I forgot to ask you if your wheel tracks disappeared after two days.
You will be able to plant/spread grass seed to make the turf even
better if the snow melts quickly this week-assuming you have snow
in Lyme.
/ Let's talk flail mowers #1,111
in Lyme.
We got some snow, but it was only an inch or so. I didn't have many spots where I even had wheel tracks. I have the mower shifted so I can get out over the edge of the ponds, and it's fun to watch it turn into nothing. I did notice that when I was mowing my normal grass that I was getting groves from the flail, like stripes. I guess I need to lower the side skids to prevent this. The good news is I don't have to worry about dethatching now!
/ Let's talk flail mowers #1,112
Check the tips of the grass slicers to be sure they have not been dulled.
I love it when a plan comes together:thumbsup:
/ Let's talk flail mowers #1,113
Help discussion.
Are the L or Y shapped cutters considered rough cut while the "cup" style considered fine cut blades? Still confussed by this and interested in understanding this before lookng for a rough cut flail.
Thanks,
nck
/ Let's talk flail mowers #1,114
Helpful discussion.
Thanks,
nck
/ Let's talk flail mowers #1,115
Helpful discussion.
Thanks,
nck
The cup style knives are finish cut. Y shaped are also typically finish at least within the Caroni line. The L shaped can be either finish or rough cut and are mounted in pairs. On the Caroni they are used as rough cut. The last type, the forged or cast "hammers" are I believe either finish or rough but I've never used them.
/ Let's talk flail mowers #1,116
Fine cut often refers to the number of knife stations on the cuttershaft. Coarse cut has fewer stations. The Mott coarse cut shafts have one Y blade per inch (a two blade station pair does two inches).
/ Let's talk flail mowers #1,117
Helpful discussion.
Thanks,
nck
The paddle type/very wide scoop knives are ment for agricultultural crop shredding,
The narrower scoop knives are ment for either grass or light brush.
The Y blade grass slicers which also look like an L knive are ment for rough or fine grass cutting dependjng upon whether they are a standard grade, hardened, or carbide coated grass slicer.
The towed motorised flailmowers offered in Europe may have a heat treated/ heavy duckbill hammer knive or a Y blade grass slicer for fine and rough cutting in verges/ roadway mowing or pasture/overgrowth
Please let us know what type of mowing/brush control work you are intent on persuing with a flail mower before you make any decisions.
/ Let's talk flail mowers #1,118
HI Guys,
Thanks for your input. So I am concluding from what has been said is that the fine vs the rough has as much to do with the spacing of the blades as it does the style of the blades, is that correct?
I attached a picture of some blades which I though were Y style, but now I am not sure. Can you identify the style from this photo?
We have a old bush hog that we use for pasture, creekside, around fruit trees, etc. Some brush, but not very often. Looking now for a flail mower that we think will leave a cleaner look more lawn like, without the wind-row. Also esier to store and handle since it is designed close to the rear wheels. Like the idea that some have a ft or two overhange on the right side so you get a littel closer to fence post,etc. Seem to have some high grass, because for one reason or other we don't get at it as fast as we should. Has some Timothy, clover, etc. So assume a rough style cutter would be better, in fact, we did try an Ford flail mower, handled really nice, but we were told after buying it that was a "finish" mower. Burned up some belts and didn't cut well at all. Probably needed sharpening. Ha.
Thanks for any suggestions.
nck
View attachment Flail mower cutters.bmp]
/ Let's talk flail mowers #1,119
HI Guys,
nck
View attachment 236803]
Those are the blades/knives from a Ford 917 flail mower. Flailmaster has them as well as New Holland.
http://www.tractorbynet.com/forums/attachments/118882-lets-talk-flail-mowers-98.html#post2070762
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
1988 Kenworth W900 Day Cab (A62613)
1988 Kenworth W900...
