whirly
Gold Member
- Joined
- Sep 3, 2011
- Messages
- 295
- Location
- Pepe'ekeo, HI
- Tractor
- Fordson Power Major, Kubota MX5100HST
I don't know why not.
It uses the standard open-ended implement mounting pins. I know I've seen some pins that were a Cat2 pin with a Cat1 threaded section, I even think Agri-supply sells some. Those would bolt right on.
You might have to mod the top link as the Caroni yoke is the right width for a Cat1 link (unless Cat1 & Cat2 are the same width, I don't know).
The standard spacing for Cat1 lift arms is 26", the standard for Cat2 is 32" but of course they have quite a bit of swing.
Also the way the Caroni is made, there are two pin positions for changing the offset (about 7"). I measured mine & if you used the two outer pin positions your pin spacing would be around 33".
Of course I've not tried it since I don't have a Cat2 tractor handy.
Hope that helps.
TD
Thank you - Good info
I realized after I posted that, that your top link wouldn't be centered if you used the two outer mounting points.
No sweat - it was a "thinking out of the box" thing which is much appreciated.
The issue is more of having the extendable/moveable unthreaded lengths and correct eye bearing bushings
width for the top link spacing or the slot.
Thank you - I forgot about the availability of bushings to downsize to the cat 1 bolt size.
