Wire rating
/ Wire rating #1
Trainer
Arkansas
Massey-Ferguson 220-4
Anyone know the amp load for 10-2 w/ground wire. Thinking about putting in an outlet for my camper and I have some 10-2 wire.
/ Wire rating #2
Normally it is 30 amps for copper. Not sure if aluminum but less. If you go to long run (like 100 feet) it will drop. Are you running a 110 or 220 circuit or do you need both? If you are trying to run a 110/220 circuit you need 10-3 with ground and not 10-2. Don't miss the insulation factor either, if running for camper suspect this will be outside and be either in conduit or buried or both.
/ Wire rating #3
30 amps of 110 or 220 or 600 volts. I have a huge roll leftover from my generator transfer plug.
The standard 30 amp RV plug can be used on the 30 amp circuit and you can use a 30 amp breaker on the circuit if you run the 10-2 all the way to the panel.
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2021 Ford F-150XL (A62180)
2021 Ford F-150XL...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59910)
2016 FREIGHTLINER...
KING 7 SHANK CHISEL PLOW (A63290)
KING 7 SHANK...
Case International 9170 w/ Duals (A64047)
Case International...
