Where does your tractor sleep?
/ Where does your tractor sleep? #141
Mine is in my 2 car garage, it kicked my truck out. Thinking of a "garage in a box" for the truck to sleep in the winter.
Also thinking about a lean-too off the back of the garage but need to get some ideas on how to build it off my brick garage.
/ Where does your tractor sleep? #142
/ Where does your tractor sleep? #144
Mine is in the tractor port, added on to the garage. Should have made it bigger, since I'm running out of room
for the attachments.
/ Where does your tractor sleep? #146
In the summer under our deck so the paint don't fade. In the winter in our heated garage for ease of snow plowing.
/ Where does your tractor sleep? #147
/ Where does your tractor sleep? #148
Nice looking job Gusman what is that 26x40? Will you insulate the exterior walls?
It is 38x 60. 17 ceilings Someday I might insulate but big money.
/ Where does your tractor sleep? #149
Yes I understand on insulation - I built a two story 24x36 in 2000 and it was quoted at $1400 to do batt insulation by a contractor R19 exterior and R38 Roof - wish I would have done it then. I didn't do it as that meant I needed to finish the interior too another $3K.
Once it fills up and you hang stuff on the walls it becomes a chore - here's my tractor house..
/ Where does your tractor sleep? #150
I had an estimate of 5600 to insulate and t&g wood is another 4800
/ Where does your tractor sleep? #151
Here's my Toy Box. The main barn is 32' x 70' and is framed in hand hewn White Oak. Nearest dating is the 1810s based on the wood, saw markings, and joinery techniques. I manage to keep my tractors, wagons, and classic Boston Whalers inside along with lumber and other construction materials. The wing barns house implements, snow machines, lumber, and more trailers.
/ Where does your tractor sleep? #152
/ Where does your tractor sleep? #153
Mine rests here with its other siblings and a goat !!
/ Where does your tractor sleep? #154
In a 24x32 garage
Sent from my iPad using TractorByNet
/ Where does your tractor sleep? #155
In the 3rd stall of my garage that stays above freezing most of the winter and plugged in 24/7
/ Where does your tractor sleep? #156
My almost finished tractor barn
just need to do some more finish work, battens & corner pieces then add in some more fill
no more sun/wind/snow/rain on my favourite toy, i mean tool
/ Where does your tractor sleep? #157
Recently put up a 48x30 pole barn to store the tractors and a few of the implements.
/ Where does your tractor sleep? #158
20141226_133122.jpegIn the garage with everything else that will fit in there.
/ Where does your tractor sleep? #159
Magicman710-
Plan on erecting similar shed soon. Still shopping for material delivered/erected in MS Delta area
Who did the package come from and did you erect or supplier??
kneedeep
/ Where does your tractor sleep? #160
Magicman710-
kneedeep
We used a builder from South Georgia, around Moultrie, for ours. Maxwell Metals is the name. They built it in 2 days.
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
2015 Evinrude G-2 250hp Outboard Boat Motor (A66738)
2015 Evinrude G-2...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2013 CHEVROLET SILVERADO 1500 (A67714)
2013 CHEVROLET...
1 TIRE BALANCER (A66091)
1 TIRE BALANCER...
