Where does your tractor sleep?
/ Where does your tractor sleep? #141
Mine is in my 2 car garage, it kicked my truck out. Thinking of a "garage in a box" for the truck to sleep in the winter.
Also thinking about a lean-too off the back of the garage but need to get some ideas on how to build it off my brick garage.
/ Where does your tractor sleep? #142
/ Where does your tractor sleep? #144
Mine is in the tractor port, added on to the garage. Should have made it bigger, since I'm running out of room
for the attachments.
/ Where does your tractor sleep? #146
In the summer under our deck so the paint don't fade. In the winter in our heated garage for ease of snow plowing.
/ Where does your tractor sleep? #147
/ Where does your tractor sleep? #148
Nice looking job Gusman what is that 26x40? Will you insulate the exterior walls?
It is 38x 60. 17 ceilings Someday I might insulate but big money.
/ Where does your tractor sleep? #149
Yes I understand on insulation - I built a two story 24x36 in 2000 and it was quoted at $1400 to do batt insulation by a contractor R19 exterior and R38 Roof - wish I would have done it then. I didn't do it as that meant I needed to finish the interior too another $3K.
Once it fills up and you hang stuff on the walls it becomes a chore - here's my tractor house..
/ Where does your tractor sleep? #150
I had an estimate of 5600 to insulate and t&g wood is another 4800
/ Where does your tractor sleep? #151
Here's my Toy Box. The main barn is 32' x 70' and is framed in hand hewn White Oak. Nearest dating is the 1810s based on the wood, saw markings, and joinery techniques. I manage to keep my tractors, wagons, and classic Boston Whalers inside along with lumber and other construction materials. The wing barns house implements, snow machines, lumber, and more trailers.
/ Where does your tractor sleep? #152
/ Where does your tractor sleep? #153
Mine rests here with its other siblings and a goat !!
/ Where does your tractor sleep? #154
In a 24x32 garage
Sent from my iPad using TractorByNet
/ Where does your tractor sleep? #155
In the 3rd stall of my garage that stays above freezing most of the winter and plugged in 24/7
/ Where does your tractor sleep? #156
My almost finished tractor barn
just need to do some more finish work, battens & corner pieces then add in some more fill
no more sun/wind/snow/rain on my favourite toy, i mean tool
/ Where does your tractor sleep? #157
Recently put up a 48x30 pole barn to store the tractors and a few of the implements.
/ Where does your tractor sleep? #158
20141226_133122.jpegIn the garage with everything else that will fit in there.
/ Where does your tractor sleep? #159
Magicman710-
Plan on erecting similar shed soon. Still shopping for material delivered/erected in MS Delta area
Who did the package come from and did you erect or supplier??
kneedeep
/ Where does your tractor sleep? #160
Magicman710-
kneedeep
We used a builder from South Georgia, around Moultrie, for ours. Maxwell Metals is the name. They built it in 2 days.
PALLET OF MEC 8000 PUMP AND V8 ENGINE BLOCK (A67714)
PALLET OF MEC 8000...
12IN CENTRIFUGAL PUMP (A67714)
12IN CENTRIFUGAL...
HONDA generator (A64553)
HONDA generator...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
2025 Mini Excavator Attachment Set (A66734)
2025 Mini...
