What to use for gate posts
/ What to use for gate posts
Any recommendations for a chain and lock. At least something to combat a common bolt cutter. It's temporary until I can get a solar opener on it in the spring.
/ What to use for gate posts #42
Get a cable -- it's a little harder to cut than chain (and very difficult with bolt cutters). Lowes sells 3/8" coated Schlage lock cables -- I think the 7 footer is about $8. I used to loop that around gate and post a few times. Shorter cable might be fine.
Ah yeah hadn't even thought of cable. Thx!
/ What to use for gate posts #44
/ What to use for gate posts #45
Great thread, found more information here than searching Google for an hour. I'm probably just going to go with a couple of galvanized steel pipes, maybe some treated lumber, however, if I decided to build a couple of rock pillars, what would be the best way to attach the gate to the stone?
/ What to use for gate posts #46
I used 4 and a half inch steel pipe sunk in holes about 4 feet deep with added concrete for a somewhat heavy 14 foot swinging and decorative gate. That was years ago and I know I overbuilt it - but it has not budged and gate closes perfectly - level and plumb. I am an advocate of building it right once. I bought a 20 foot pipe and cut it down - it was threaded at both ends so I also added a cap.
That was for a main entry gate to our drive way at the highway. For other gates - farm and cattle gates - I have used wood, or other metal posts I already had around. I have braced the posts at the hinged side with other posts and wiring.
20' DOUBLE AXLE INDUSTRIAL TRAILER (A59823)
20' DOUBLE AXLE...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
1999 John Deere 7810 (A60462)
1999 John Deere...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2007 Ford Taurus Sedan (A59231)
2007 Ford Taurus...
2013 Ford Focus Sedan (A59231)
2013 Ford Focus...
