What to use for gate posts
/ What to use for gate posts
Any recommendations for a chain and lock. At least something to combat a common bolt cutter. It's temporary until I can get a solar opener on it in the spring.
/ What to use for gate posts #42
Get a cable -- it's a little harder to cut than chain (and very difficult with bolt cutters). Lowes sells 3/8" coated Schlage lock cables -- I think the 7 footer is about $8. I used to loop that around gate and post a few times. Shorter cable might be fine.
Ah yeah hadn't even thought of cable. Thx!
/ What to use for gate posts #44
/ What to use for gate posts #45
Great thread, found more information here than searching Google for an hour. I'm probably just going to go with a couple of galvanized steel pipes, maybe some treated lumber, however, if I decided to build a couple of rock pillars, what would be the best way to attach the gate to the stone?
/ What to use for gate posts #46
I used 4 and a half inch steel pipe sunk in holes about 4 feet deep with added concrete for a somewhat heavy 14 foot swinging and decorative gate. That was years ago and I know I overbuilt it - but it has not budged and gate closes perfectly - level and plumb. I am an advocate of building it right once. I bought a 20 foot pipe and cut it down - it was threaded at both ends so I also added a cap.
That was for a main entry gate to our drive way at the highway. For other gates - farm and cattle gates - I have used wood, or other metal posts I already had around. I have braced the posts at the hinged side with other posts and wiring.
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
UNUSED X-STAR 101"x20' LOADING RAMP (A64280)
UNUSED X-STAR...
2025 48in. Farm Jack (A61572)
2025 48in. Farm...
2022 John Deere 5055E (A62177)
2022 John Deere...
2019 Ram 3500 4x4 Service Truck (A61573)
2019 Ram 3500 4x4...
