Fencing and Posts
/ Fencing and Posts #32
I'm building a fence around my place to keep cattle, horses and goats in, but also to keep wild hogs out. For my fence, I'm putting 6 inch round posts in at my corners, and every 100 feet. I'm putting 6 foot T posts in every ten feet. My fence is four feet tall, 2x4 horse fence. It's super expensive, but because of my goats and horses, I don't want to use anything with a smaller spacing. I also use the same 2x4 fencing on my dog yard.
From what I'm seeing, your costs are about as good as I've seen. I just paid $5.09 for 6 foot T posts.
If you are going to add wood rails to the posts, then the 8 foot spacing makes sense, but then you really don't want to try to attach wood rails to T posts. I would reconsider that idea and then spread you T posts out farther. For high tensile field fence, you can easily go 15 feet apart for your T posts. Especially if all you are doing is marking your property line and keeping your dogs in. I've read that some high tensile fence manufactures say that you can go 25 feet in spacing your T posts. Where I have my cows, I've been paying attention to what everyone else is doing, and it's all over the place. I've seen T posts spread out 15 feet apart, and running for thousands of feet with just T posts. I've also seen fence lines with all wood posts without any T posts used to hold in cattle. I'm not sure if there is an actual wrong or right way to do this since nobody really seems to know, or care. My goal is to build it as good as I can, and not have to do it again.
How are you stretching your wire? I bought one of these 4 foot stretcher bars from Kencove that I highly recommend. I put a come along on the top and another on the bottom, and I can really pull the fence tight quickly and easily on my own. I use my backhoe with some chains to anchor the come along's.
We used 5' 2"x4" for horses and electric to keep them off the fence. The goats figured out of way to escape on a regular basis. They would go under so I ran high tensile along the bottom. That slowed them down but didn't stop them if they saw something the wanted. Electric at the bottom works but you have to keep the weeds off of it.
/ Fencing and Posts #33
What kind of fencing do you use them on?
All the best, Peter
Either the field fence like the OP has or barbed wire. What is nice is I can install them while I'm on the other side of the fence with a screw gun.
/ Fencing and Posts
I did consider 3 strand barb wire on sides and back; for cost savings; but I think I'd rather the field fence. No matter what, it's gonna a pretty expensive.
/ Fencing and Posts #35
I'm a bit surprised by the negative comments on wood posts. I guess it's a regional thing because I've had great luck with round wood posts in the ground. My soil is acidic red clay, my climate is humid with an average of almost 60 inches of rain in a year. It's not uncommon to get a few thunderstorms that drop 3 inches in an hour or two a few times a year. One inches of rain from a thunder storm is common.
In my experience, I've neve seen a wood post of any kind rotted out in the ground. In every case, the part that in the ground is always pristine. Almost brand new looking. The rot is always at ground level, where the water sits around the base of the post after it rains. Usually this is a low area that doesn't drain. When I replace these posts, I build up the soil or concrete so the water flows away from the post. In the last couple of years, I've removed several of my wood posts to change the location of my fence, and 100% of them where in perfect condition, even though some of them have been in the ground 20 years. Some have only been in the ground 10 years. They are also mixed between being set in concrete and packed dirt. The ones in dirt come out easier then pulling T posts. The ones in concrete take the most effort to get out.
All of my wood posts are round. The worse post for anything is a treated 4x4 because they twist and bend more then anything else. They used to be fine, but when all the changes happened to how they had to be made, they are no longer worth using. I'm not even comfortable with 4x6 treated posts for anything higher then a foot or two above grade.
For staples, I'm still hammering in the barbed staples. I looked at a few of the staple guns out there, but the barbed staples that I saw where not hot dipped galvanized, and they where thinner then the ones I'm hammering in manually. Some of them will only take smooth staples, which I believe are worthless.
To make it a little easier, I have a tool that holds the staple while I get them started. They staple fits into a slot, and after you place the staple, you hammer the tool until it's started. Something that surprised me was how important a good hammer is. I have several hammers, and I started out using a solid wood handles hammer. But my forearms started hurting so bad that I almost gave up, but then I tried my Bostic framing hammer with a rubber type handle for the gripping area, and all the pain I was having when hammering wasn't there.
I'll add that when a post does rot off at ground level, and you want to replace it with another post in the same spot, getting the part that's left in the ground out is a royal pain. I have a corner I need to deal with and I'm dreading it.
/ Fencing and Posts #36
Yep...that is what I'm dealing with...more than a few.
/ Fencing and Posts #37
Usually the worst wood is within a few inches of ground level. The in-ground section may be still really solid.
I would get a screw eye or hook, 1/2 inch or larger, and 12 inches or so long. Drill a pilot hole to help prevent splitting the post, screw in the eye/hook into solid wood, and pull up.
Bruce
/ Fencing and Posts #38
I enclosed about 8ac with 10' posts; there's 5' horse fence (2x4 woven) and then three strands of barbless above that with 8" gaps; there's a hot wire in the gap between the horse fence and the first barbless on the outside. 6" posts at the corners and bends, and then after every 3 or 4 t-posts. Used an angle iron+rebar+bolts stretcher with the tractor tugging.
I've pulled pt wood posts that I sunk 25 years ago and by and large they're fine; they had the same chemical mix then as now, so I'm confident with what I put in the ground.
My target was keeping wildlife out and potentially goats in if I can convince my wife that they're a win.
So far, no coyotes have climbed the fence, and the bobcat is staying out - haven't lost a chicken since the fence has been up.
/ Fencing and Posts #39
Other thing I did was fence charger, t post top insulators and porcelain insulators for wood posts. A driven ground for charger black ground terminal also wired to woven wire fence. My thought is the more ground the better and many feet of woven wire with t posts every 10ft makes a super ground all the way around.
/ Fencing and Posts #40
Plus that way anything that touches the hot doesn't have to touch the ground, any part of the fence will do. Helps with climbing animals.
DEUTZ MARATHON...
INGERSOLL RAND G25 GENERATOR (A60736)
INGERSOLL RAND G25...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
pressure washer, and trailer (A56859)
pressure washer...
2023 Chevrolet Tahoe FL SUV (A59231)
2023 Chevrolet...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
