T-posts in hard ground - a hack
/ T-posts in hard ground - a hack #41
I had about 65 locations where the exposed bedrock made me use 2x4 - "L" posts. My neighbor has a commercial air compressor/jack hammer. This will be the final year where we replace the last "L" posts with T-145 steel posts. That jack hammer makes a 2" hole, about 16" deep, fairly quickly.
/ T-posts in hard ground - a hack #42
How big is the jack hammer? Do you have any info on model/cost.
/ T-posts in hard ground - a hack #43
Bill - the actual hammer is pretty big and it's heavy. The air supply comes from a three cylinder diesel mounted on a trailer. It's the type you see at highway construction projects. It is DEFINITELY not a homeowner model. He tows it around with his pickup. When he gets here - I tow it with my tractor. He let me try the hammer once. Got down about 6" and he took over. The major concern - getting the bit stuck in the hole you are drilling.
There is compressed air hissing everywhere - dust and rock chips flying all around. It makes quick work of our basaltic lava.
/ T-posts in hard ground - a hack #45
That's pretty slick. A very cute girl and a slick way to pull a T-post.
/ T-posts in hard ground - a hack #47
I have some exposed rock on my property. I bought the largest hammer/demo drill Makita makes (SDSmax) Purchased a 1.5'' drill bit and drilled the rock and hammered the T post into the hole.
No need to cement in as the 1.5'' hole is a very tight fit for T post.
You just have to knock the plate off the T post
/ T-posts in hard ground - a hack #48
Our clay soil doesn't give up a T post once shes been in the ground for a fw years. Takes a big tractor to pull em out and they take a lot of bonded dirt with them.
/ T-posts in hard ground - a hack #49
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
Electric Concrete Mixer (A61166)
Electric Concrete...
2022 Case SV280 (A60462)
2022 Case SV280...
2020 DRAGON ESP...
2022 New Holland C327 Compact Track Loader (A61307)
2022 New Holland...
