Electric fence advice
/ Electric fence advice #21
.15 joule doesn't seem like much . But if it works...... I guess mine is over kill @ 32 jouels
I totally agree and was concerned that it was so low. I don't know why it works to get me 9200 volts at the far end. I thought I would need at least 2 joules - and I read that a joule a mile is recommended. The units I checked out at TSC were mostly under a joule, one at 2.2, and another at 4 I think but it was over a thousand dollars. 32 joules would likely work at San Quentin.
/ Electric fence advice #23
/ Electric fence advice #24
The number of joules needed has a lot to do with the lack of resistance of the wire or tape. Heavier wire will work better, copper wire works a lot better, and stainless is ok. We use a braid of polyethylene, stainless and tinned copper. Copper is nearly a thousand times more conductive than steel.
All the best,
Peter
/ Electric fence advice #25
I don't know how a .15 would shock but I can tell you that 32 feels like you stuck your hand into 240 volts !
I was bent over close to the wire never thinking about it. I accidently raised up, touched the wire with my head, and it felt like someone hit me across the back of my neck with a ball bat ! And that was with rubber sole boots on.
I've seen my 2300 # bull touch, it and heard him scream ! Never heard a scream like that. He is grounded with four feet on the ground though .
They may not make a solar charger that large though
JOHN DEERE 7230R TRACTOR (A60430)
JOHN DEERE 7230R...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59905)
2020 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 CATERPILLAR 305E2CR EXCAVATOR (A60429)
2018 CATERPILLAR...
2022 Horizon Trailer (A55973)
2022 Horizon...
UNUSED IRANCH 15" TOOTHBED MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 15"...
