Electric fence advice
/ Electric fence advice
.15 joule doesn't seem like much . But if it works...... I guess mine is over kill @ 32 jouels
I totally agree and was concerned that it was so low. I don't know why it works to get me 9200 volts at the far end. I thought I would need at least 2 joules - and I read that a joule a mile is recommended. The units I checked out at TSC were mostly under a joule, one at 2.2, and another at 4 I think but it was over a thousand dollars. 32 joules would likely work at San Quentin.
/ Electric fence advice #23
/ Electric fence advice #24
The number of joules needed has a lot to do with the lack of resistance of the wire or tape. Heavier wire will work better, copper wire works a lot better, and stainless is ok. We use a braid of polyethylene, stainless and tinned copper. Copper is nearly a thousand times more conductive than steel.
All the best,
Peter
/ Electric fence advice #25
I don't know how a .15 would shock but I can tell you that 32 feels like you stuck your hand into 240 volts !
I was bent over close to the wire never thinking about it. I accidently raised up, touched the wire with my head, and it felt like someone hit me across the back of my neck with a ball bat ! And that was with rubber sole boots on.
I've seen my 2300 # bull touch, it and heard him scream ! Never heard a scream like that. He is grounded with four feet on the ground though .
They may not make a solar charger that large though
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
Selectatilth 3pt 9' Rotavator (A64126)
Selectatilth 3pt...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
