Question about footings
   / Question about footings #1
kcir
Lake Fork, Texas
Kubota 5400
I am wanting to build a 20x40 concrete pad 4" with a metal roof only, no sides. What kind of foooting do I need around the peremiter? 12"X12", 18"x18"?
I am in east Texas so no frost/freeze. Does anyone here know?
Thanks,
Rick
   / Question about footings #2
What kind of soil? Compacted or loose?
   / Question about footings #3
The footing size would be determined by the loading.:D
It's a hard sand, not red sand the yellow sand. Loose sand will get very hard here after a good rain. So sand/clay.
   / Question about footings #5
check with local contractors and see what is the norm for the locaton...
   / Question about footings #6
With "no sides" on your structure all the weight will be bearing on your posts,right? If that be the case,you do not need a perimeter footer.
   / Question about footings #7
Thanks,
Rick
Posts in the ground or on the slab?
   / Question about footings #8
It should depend on the two above. I just poured a 12ft X 28ft foundation a couple of weeks ago and we went 18 inches wide based on the soil and building load.
   / Question about footings #9
Mousefield:
Just curious, what is the slab inside the one end of the footing for?
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
2018 KENWORTH T800 (INOPERABLE) (A53843)
2018 KENWORTH T800...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
