Question about footings
/ Question about footings #1
kcir
Lake Fork, Texas
Kubota 5400
I am wanting to build a 20x40 concrete pad 4" with a metal roof only, no sides. What kind of foooting do I need around the peremiter? 12"X12", 18"x18"?
I am in east Texas so no frost/freeze. Does anyone here know?
Thanks,
Rick
It's a hard sand, not red sand the yellow sand. Loose sand will get very hard here after a good rain. So sand/clay.
/ Question about footings #5
check with local contractors and see what is the norm for the locaton...
/ Question about footings #6
With "no sides" on your structure all the weight will be bearing on your posts,right? If that be the case,you do not need a perimeter footer.
/ Question about footings #7
Thanks,
Rick
Posts in the ground or on the slab?
/ Question about footings #8
The footing size would be determined by the loading.:D
What kind of soil? Compacted or loose?
It should depend on the two above. I just poured a 12ft X 28ft foundation a couple of weeks ago and we went 18 inches wide based on the soil and building load.
/ Question about footings #9
Mousefield:
Just curious, what is the slab inside the one end of the footing for?
/ Question about footings #11
Mousefield:
After we framed the out side foundation we decided to make an 8ft X 12ft room, so the pad is that area. We will fill in the three side to make it solid to the outside foundation. We had to leave the 6 inch gap to get the framing wood out. It's called hindsight. :laughing:
/ Question about footings #13
Thanks,
Rick
Rick, If I were you I would call your local concrete company and tell them what you intend to use it for and then ask them about the type footers you need , I am assuming there is no building permit required and no building code office..but if there is , then you could call your local code office and ask them what the code is ...if you are going to permit it...:)
/ Question about footings #15
Rick for the type of structure you want the easiest thing to do is build it like a pole barn. Set your poles, build your roof and then come in and pour a slab. The slab will be a floating or sometimes called an Alaskan slab. Along the edges you dig a trench, in this case 8 or 10" deep would be enough, that slopes at 45 degrees to the main body of the floor.
MarkV
