My Stupidity kicked in at full throttle.
   / My Stupidity kicked in at full throttle. #101
I wouldn't try brute force. I had a PTO shaft on a tiller that was locked up. I tried pulling on it with the loader (brute force). Didn't work. I sprayed the heck out of it with PB Blaster, put strap through the PTO yoke, and hooked it to a come a long on a tree and applied tension. I let it sit overnight and kept spraying it with PB Blaster. Then, I took a hammer and did a tap, tap, tap. It came right apart.
If spraying oil on it doesn't work, try brake cleaner, carb cleaner or solvent. A soft touch is better than brute force.
Good Idea. Maybe an air hammer to get some vibration. I used this method to get a PTO of a lawn tractor.
   / My Stupidity kicked in at full throttle. #102
A come-along for tension. Several applications of penetrating oil. Wrap a dripping wet rag around the PTO-apply heat. Keep rag wet. When hot-start tapping with a hammer.
   / My Stupidity kicked in at full throttle. #103
OP solved the problem by page 5, now up to page 11.
My only thought is, I'm amazed how many people are saying "Pull on it"
and/or "Hammer on it".
FYI, there are ball or roller bearings, among other components, inside the case that don't respond
well to shock loads. A puller that pulls on the yoke and pushes on the end of the PTO shaft is the
only smart way to get the yoke off without possibly causing more problems.
Hammering the yoke on was the first mistake. Glad it worked out.
   / My Stupidity kicked in at full throttle. #104
I bought a new 2024 Mahindra 1126 tractor. I have put around 70 hours on it. Until this past Saturday it had never had it's PTO stub uncovered. When I took the cover off the stub looked very smooth and black. I intended to connect a new 48" rotary cutter to the tractor. Every thing looked good and clean in the PTO shaft yoke.
Well the shaft went on to the stub about 1/2". From there I used a block of wood and drove it on, as far as it would go. About 1/4" from the lock pin groove.
My thought when driving it on was that it would free up while I was using it. But I ain't gonna use it for fear that the shaft will free up and sling off.
Now to my question. Does anyone have any suggestions as to how I am gonna git the shaft off. I am disconnected from the rotary cutter with the cutter end of the drive line separated from the tractor end of the drive line.
My thought is to tie the shaft to a tree and drive off with the tractor.
I am open to any other ideas.
When I git this apart I will be cleaning the powder coat paint off of the stub.
Mule
I wouldn’t use brute force or hammer it off or heat it up.All those methods could cause expensive damage. Rig up some type of a wheel puller that will just pull it off.
   / My Stupidity kicked in at full throttle. #105
My experience is Tieing it to the tree does not work and could be a very bad thing. Lots of penetrating oil, patience, and tap, tap, tap win the day eventually.
   / My Stupidity kicked in at full throttle. #106
Mule
Did you try calling the dealer, checking the manual, or searching YouTube? The last two are my go-to. I have a 94 JD. Holding the little button down while pushing them on is very frustrating.
   / My Stupidity kicked in at full throttle. #107
   / My Stupidity kicked in at full throttle. #108
I would not pull or pry too much or hard on it. you take a risk of damaging the shaft internally. if all else fails I would cut a slit in the drive shaft yoke to free & remove & replace the yoke.
   / My Stupidity kicked in at full throttle. #109
Expect more on this. The thread was sent out to email accounts everywhere today.
Trending Topics
Here are today's popular topics from TractorByNet​
When I recieved it I thought"A bit late for the party, aren't we?"
   / My Stupidity kicked in at full throttle. #110
Mule
Well, by now you know that you shouldn't have hammered it on so I won't text any more about that. You should be able to get it off by heating the entire engaged portion with oxy-acetelene and tapping gently. You may need to heat until just slightly red and that could take some time so don't be impatient.
Good luck.
   / My Stupidity kicked in at full throttle. #111
Yes, a great way to cause oil leaks as well as expensive damage to repair.
A bit of grease on the shaft and yoke works really well for me. If I can't lever off a stuck pto with a big screwdriver, it is time to go to plan B which doesn't include brute force or a hammer.
It is amazing how many PTO mount/unmount problems were solved when I started greasing the PTO stub shaft and yoke receiver before attaching things.
   / My Stupidity kicked in at full throttle. #112
Good luck.
This is apt to cause a lot less damage. That much heat on a tractor that small is apt to cause a lot of damage to the drive line.
   / My Stupidity kicked in at full throttle. #113
Farmall went out of business! If only they'd put a condom on their PTO's... :p
International Harvester (IH), which produced the Farmall brand, sold its farm equipment division to Tenneco in 1984, the Farmall brand itself wasn't entirely gone, as Case IH revived it in 2004, and Farmall tractors are still produced today.
   / My Stupidity kicked in at full throttle. #114
Heat.... Make the thing expand, then the hammer and ratchet strap.
   / My Stupidity kicked in at full throttle. #115
Never figured out the advantage of using Kriol as a penetrant with PBlaster works better and is much cheaper. If you are really a cheapskate, use a 50-50 mixture of Acetone and red ATF in a spray bottle.
Kroil reminds me of Marvel Mystery Oil. Basically worthless stuff that is expensive.
"Kroil, the Oil that creeps". A lot of folks swear by it, but I'm with you. I bought the advertising line a long time ago and bought a gallon can of it. Never found anything that it worked well on. Still have most of the gallon left.
   / My Stupidity kicked in at full throttle. #116
Kroil is almost the best but to penetrate and possibly soften the paint 50/50 ATF and Acetone test the best. Otherwise I agree with this post by air biscuit
   / My Stupidity kicked in at full throttle. #119
I looked at a picture of the pto on your tractor. I would use caution if you decide to use the tractor to pull pull against the pto shaft. The pto housing could be cracked or broken if you snatch too hard. A puller would be best if it could be made to work. Applying some heat to the Adapter Sleeve will cause the tube to expand slightly which may loosen it enough to be tapped off (do not overheat). Use solvent as mentioned already. You might also try gently tapping a wedge (wood splitter etc) between the Adapter Sleeve and the pto housing. Hope this helps!
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Ram 1500 4x4...
2013 HAM 289I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAM 289I-30 8...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
