5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,772
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Seems like every time a poster posts a picture of their tractors, they are always filthy. Myself, I'd be offended to post a picture of mine (remember, I have more than one) being dirty, you won't find mine dirty unless I just came in from the field and last thing I do is wash them I cringe when I see that because removing and installing parts on a filthy tractor is inviting the filth inside the works... and
The other thing I see on here when someone posts a picture of the backend of their tractor, the remote female connectors never have any plugs in them. My remotes (I have 3 sets on each tractor) are always capped when not in use, You can buy rubber lanyard caps at TSC for cheap or spring for the spring loaded self closing ones that any Kubota dealer sells (what I have). Leaving the remotes open and dirty inside causes internal rust plus they won't seal to the male ends properly and leak and replacements aren't cheap.
I also cover my PTO shaft when not in use. You can buy slip on plastic pto stub covers cheap as well. Keeps then clean and rust free and you can put a bit of grease in the cover as well.
Just things I notice when looking at tractors on this site...
