Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat
I have a nearly identical setup with my Branson. My engine hp is 37, but my pto hp is 32. Almost an exact duplicate of what you're running. Mine is also "heavy" (4200 lbs bare chassis) and my rear tires are also filled with Rimguard. All that to say, I am also running a 6' brush hog, and our summers regularly get to 90-95 degrees with humidity. The only time I have issues with getting hot is once my radiator and coolers get plugged with chaff from mowing. And I'm running a cabbed tractor with a/c. And when it's hot out, you better believe I have that a/c cranking.
Once I blow the chaff out of my radiator and coolers, the temp gauge drops right back to the normal range again. Sometimes I can go for hours, sometimes all day, sometimes I have to stop every "lap" I take on the field. It really depends on the field and how much chaff I'm kicking up on that job. Last job I did the field was very soggy wet so there was no chaff at all to contend with. I ran for 6 hours straight (well I did stop to replace one broken shear pin) with no overheating issues at all. Meant to add, this was a field with average weed/grass height of top of the hood, and a few areas where the weeds were 6 feet tall.
Point of all this ramble? I don't think you need to second guess your tractor choice, either size or hp rating. There's something else at play here.
Thanks for the useful identical configuration comparison. I have hills and when this overheating process begins I can watch the temperature gauge start going up going uphill and go down going down. The chaff building up sounds so similar. I do hop down and blow it off with a leaf blower and start the cool down, then heat build-up process - over and over and sometimes it is one lap. This is useful to know - and I'll try cutting open the thermostat to eliminate it not opening. That would serve as a "restrictor".
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #42
I only ever blow out the radiator from the engine side outwards to the front. Never blow from the front side in. If you do that you are blowing chaff deeper into the rows of fins. Blowing it only from the back side forwards forces out through the path of least resistance and you're more likely to get most or all of it out.
I tried to use a leaf blower once and just couldn't get it in the tight spaces and between the fan, fan shroud and get it close enough to the back of the radiator to do any good. Wasn't getting enough air actually directed through the rows of fins. I use the air wand out of the "Radiator Genie" set, which easily fits and reaches across the entire back side of the radiator (coming in from both right and left sides).
I also set my air pressure out of my compressor to 40-ish psi. Be very careful not to hit that aluminum finned radiator with too much air pressure. Those paper thin fins are extremely easy to fold over (like when hitting them with 100-120 psi air, or scraping the wand tip across the fins).
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #43
This is a great suggestion!
Do yourself a favor and pressure test your radiator cap and coolant system before diddling around with taking the thermostat out (again).
I find it much less likely that you ran into 2 separate "bad" thermostats in a row. And frankly, it just doesn't match the symptoms you are describing.
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #44
It it used to work properly under the same conditions and you have replaced the thermostat, the thermostat is not the problem. Maybe removing it or cutting it down can make up for the real problem, but it won't fix it. I kind of doubt that a fully open thermostat is that much of a bottleneck so I don't think removing it or cutting it down will change much.
With the engine off can you turn the fan by hand? If so the belt's not tight enough. Or it's old and hard. If it's slipping both the fan and the water pump will turn slower than they're supposed to.
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #45
Very true!
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #46
Could there be a chance that the water pump impellor is slipping on the water pump shaft.
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #47
Can you see through the fins of your radiator? It has to be one of two things, either your radiator is dirty, or your fan/belt/water pump isn't working like it should. I think the thermostat is good and not worth the time to mess with.
If it was me, I would get the hose out and soak the radiator for half an hour. Just keep the hose on it until you get totally clear water coming off of the radiator. This would be cheap, fast and easy.
Then hit it with the air to see if anything comes out of the fins. Get a wand that goes onto your air hose. Mine has two feet of metal with a 90 degree bend at the end so I can get into the corners, and in front of the fan. I blow from the engine side of the radiator. I do this until I don't see any dust at all coming out. Sometimes it's just a couple minutes, sometimes it's ten minutes. Every time, there's dirt in there!!!
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #48
Rhino35, any updates? I agree with others that it's most likely an air flow issue. I too use the Radiator Genie wands because they make it easy to get between to radiator and engine to blow from back to front. Not sure about your tractor but my RK37 has a screen too that if you don't pay attention you could easily miss so that you are just blowing the trash onto the screen so that it gets sucked back into the radiator. Also, the chuck that came on my wand wasn't the standard chuck so the air leaked around it. There's a youtube video out there explaining it. I bought an adapter off Amazon for something like $7 that took care of that issue. There's also a couple good videos out there on the Radiator Genie.
A few days ago, ambient temperature about 80F, I wanted to see if the coolant was circulating since a poster said to check that. So I started the engine and slowly drove out of my garage in hydro low gear and 1300 RPM. Engine had been running only 3-4 minutes when I opened the radiator cap. Coolant splashed out - like it was overfilled. I was surprised - I thought I'd just see the coolant below the cap stationary (not under pressure like it was), and then as the engine warmed up and the thermostat opened begin to flow. The overflow bottle I've kept at about half - there is a fill line and its always been close to that when cold. It does go up and down.
I blew out the radiator with compressed air - higher PSI than 40. Probably 100 psi and then as I held the hand air valve open it dropped to 50-80 psi. Lots of fine particle dust, brownish, like before when I've done this. I blew it out front to back at first, then back to front - a long time moving all around the obstacles to get it to where no appreciable dust blew out. There is an oil cooler radiator low in front of the engine coolant radiator and that seemed to have a lot of dust. As an observation my tractor's engine coolant radiator has a lot of stuff in front of it. The battery, the oil cooler, the air filter housing, and a big air pipe from the air filter up and over the radiator top to the engine.
I can move the fan by hand about 1/8th revolution, but it takes almost all my strength. Is that too loose? Every time I've looked at the running engine at idle RPM that fan is spinning. I haven't looked at it with engine RPM at 2,500 RPM - I'd need someone at the controls before I'd do that. I moved it so I could blow out the radiator back to front where the fan blades had blocked the radiator. That allowed more dust to blow out, which was good to see. I don't think the drive belt is too loose, but possibly that is an underlying problem.
I then worked the tractor by bush hogging medium high stuff on fairly level land in two wheel drive, then engaged four wheel drive and went up and down the hillside bush hogging. Temp gauge stayed put.
I used the thermal sensing gun with the engine warmed up and stable and the gauge reading normal. All temps read plus or minus about 2 degree C as I moved the gun around. Temperature was 67C at the radiator cap, 67 degrees at the very front of the engine, and about 90C near the back of the engine. It was 67C at the rear differential area too. I'll carry the gun with me and if it starts heating up I'll check these areas again. Any tips here?
Thanks!
Finface
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #50
I would hit it with the hose and really soak it good, then blow it out with air.
When you move the fan, is it sliding along the belt, or are you moving the fan and the belt at the same time? A loose belt can cause overheating.
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #51
Have you tried using a flashlight in the dark to see if the radiator is
clean all the way to the bottom?? Also check your hoses as they get
older they can collapse and cause a restriction. Also if your coolant
is not mixed correctly your radiator can over heat. If you add water
only use distilled water. IMHO a 50/50 mix is the best
willy
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #52
Thanks!
Finface
So does it run any cooler?
willy
I haven't tried the flashlight, but I will after flushing it. I'm going out today to blow it out again and then flush the radiator with the AC cleaner (spray can) I bought. I'll rinse the living shiitake mushroom out of both the engine radiator and the oil cooler. My hoses should be okay - they look new and are flexible and the tractor is stored indoors and has only 470 hours.
After I flushed the radiator coolant in September, 2022, before doing my fall annual tall weeds/small saplings hillside bushhogging, and in hopes I'd cure this vexing gradual overheating issue I did the below - copied from my maintenance notes for my 2013 DK40SE tractor;
"September 13, 2022 - flushed radiator, installed new thermostat. New mix of fresh Kioti coolant is an additional prevent overheating experiment. Assuming faulty thermometer, but also adjusting for more water (which cools better than glycol) and adding Water Wetter product for the first time. Water Wetter from AutoZone has anti-corrosion chemicals like Kioti brand antifreeze. Final coolant mix is 4% Water Wetter, 32% propylene glycol, and 64% distilled water - essentially a 32% glycol, 68% water mix. From an online chart I found that a mixture of 30% propylene glycol to 70% water has a freeze point of 8°F, with a burst point of -18°F. The freeze point of a 32% propylene glycol and 68% water mixture is approximately 5.6°F. Kentucky winters not usually that cold, plus my garage is kept heated in winter to 40F for any engine starts should I need to work the tractor."
Hi Alan,
It did for about a 45 minute workout, but it wasn't the tall stuff and the hills. Definitely blowing out the radiator and oil cooler helped because doing about the same work in May lead to overheating.
But the margin between not overheating and overheating is pretty darn slim if all it takes is that fine dust accumulating after about an hour of work, which I blew out. I can only carry a leaf blower with me and that hasn't gotten that fine dust out enough. So I have to really get those radiator fins flushed out.
Best,
Finface
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #55
Hi Alan,
Best,
Finface
Sounds like you’re on the right track bro!
I hope so. Yesterday I blew it all out again with compressed air - and after only doing 45 minutes of work a few days ago was surprised how much of that brown dust was still in there. Then I sprayed that Nu-Calgon Evap Foam - used the whole large spray can - let it fulminate (it goes on white foam, then sorta liquifies and runs clear) for 20 minutes, and then rinsed it all out.
I also did my best to tighten the fan belt. With great effort I could turn the fan a bit without the belt moving, but it also was tight enough to turn the belt too. I did find a loose bolt at the lower engine side of the alternator, but that wasn't the bolt that could be loosened to move the fan belt tightness. I probably tightened the belt just a little - it was hard using a crow bar to push it away from the engine.
So it is supposed to rain off and on here for the next 4 days. I'll take the tractor out for bush hogging work which always resulted in that gradual overheating pattern after things dry out in about a week.
My next move if it still overheats will be to cut out the inside of the thermostat to fashion a "restrictor", or maybe remove it altogether. The logic of coolant flowing too quickly through a radiator to transfer heat to the atmosphere...I dunno about that. With restricted flow the coolant spends more time inside the engine - the other side of the equation - so it would seem logical that the possible reduction in heat transfer in the radiator would be at least partially balanced by coolant less hot coming from the engine.
I know diesel engines need to run hot to be efficient. If I take out the thermostat it will be interesting to see how much longer it takes to move the temperature gauge to the normal band - or if it even gets there. I think it will be worth the experiment - and I don't use my tractor in the winter time anyway.
I'll report back - and thanks again to all the people who offered advice.
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #57
Just a thought…..Can you go to a thermostat that opens sooner, like maybe 10 degrees?
I had an issue years ago with a drag car that would run hotter than I wanted, so I went to a 160 thermostat from a 180 that did the trick. It had a 4 row aluminum radiator cooling a 427 sb with 650+ hp.
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #58
A thermostat is designed to keep the engine at a certain temp
to run efficently
willy
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #59
How much more sludge came out with the cleaner?
Be careful of tightening a fan belt too much, too tight will take out water pump and alternator bearings. Alternators are just kind of expensive and not bad to replace, water pumps can be very expense and a royal pain to replace.
   / Chronic Kioti DK40 SE Overheating - Seeking Advice on Removing Thermostat #60
Did you use the hose to flush out the cleaner that you applied? It's odd that so many people don't want to use a hose on their radiator because they think it will create mud, or the dust will build up from moisture, but nobody refuses to drive in the rain for that same reason.
It sounds like your fan belt is nice and tight.
Since you are still getting dirt out of your radiator, you really need to get the hose out and get it all cleaned out.
CAT D8 (A58214)
CAT D8 (A58214)
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59230)
2013 Chevrolet...
2020 DRAGON ESP...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2020 FREIGHTLINER...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
